IMSTAR Rules (September 7, 2008) at MIR
Old Aug 5, 2008 | 01:16 PM
Jason Miller's Avatar
Default IMSTAR Rules (September 7, 2008) at MIR
Event: IMSTAR Sport Compact Series
Where: Maryland International Raceway
Date: Sunday, September 7, 2008
Web Site: http://www.mirdrag.com
Email me: jmiller@mirdrag.com
Admission is $20
Bracket Racing Entry Fee: $30
Heads-up Racing Entry fee: $40
Car Show Entry Fee: $30
Gates Open: 10am
Eliminations: 2pm
Bikini Contest: 3:30pm
Car Show Awards: 4pm
Street Fighter
$1,000 Winner
$400 Runner-Up
$100 Semis
Entry Fee - $40
(Your car must run 10.99 or quicker and legal with the rules below to try and qualifying for this class.)
Race Format: Quick 16 field, Pro ladder, Heads-up, Pro tree, No breakout
Body: 1987 & newer vehicles only. Aftermarket body parts are limited to hoods, trunks lids, sunroofs, wings, ground effects, bumpers, and front fenders only. One-piece front ends are not permitted. All other body parts must be stock. All windows must be functional. No body parts may be removed during competition. (VW models are permitted to run any year vehicle).
Chassis: Full stock chassis is required. Cutting or drilling for lightening purposes of the chassis is not permitted.
Suspension: Stock type suspension cars only. Aftermarket direct replacement A-arms, struts, and shocks are allowed. Wheelie bars and ladder bars are prohibited.
Street Equipment: Lexan windows are permitted. Head lights/Brake lights or decals of Head lights/Brake lights are required (one headlight may be removed for air induction). Interior is not required.
Exhaust: Muffler(s) are required unless vehicle is turbocharged.
Electronics: Two-steps, aftermarket ECU’s, and engine management systems are allowed.
Driveline: Cars originally equipped with independent rear suspension must remain independent rear suspension (IRS conversions to straight rear axle are prohibited). Aftermarket axles, gear ratios, spools, and positive traction differentials are permitted.
Turbocharger: Turbochargers are measured at the inducer wheel diameter at the point where the leading edge of the compressor wheel meets the inlet housing.
Nitrous Oxide: On cars that are not permitted to use nitrous oxide, all nitrous bottles and nitrous/fuel solenoids must be removed off car entirely.
Transmission: Aftermarket transmissions are permitted.
Fuel: Gasoline only permitted. Aftermarket fuels cells are permitted.
2-rotor cars:
· Engine must be EFI. Any style intake is permitted.
· OEM block from same manufacturer as car is required.
· Any size turbo or twin turbos are permitted. Any type intercooler permitted. May be combined with Nitrous oxide.
· RWD cars are limited to a maximum size of 28.0” x 11.5” slick or DOT slick, or any size DOT radial tire.
· No minimum weights.
4-cylinder cars:
· Engine must be EFI. Any style intake is permitted. (VW vehicles are permitted to use carburetors)
· FWD cars are limited to a maximum size of 26.0” x 10.5” slick or DOT slick, or any size DOT radial tire.
· AWD cars are limited to a maximum size of 26.0” x 10.5” slick or DOT slick, or any size DOT radial tire.
6-cylinder cars:
Wild Street
$1,000 Winner
$400 Runner-Up
$100 Semis
Entry Fee - $40
(Your car must run 11.99 or quicker and legal with the rules below to try and qualifying for this class.)
Street Equipment: All windows must be OEM glass. Headlights and brake lights are required (one headlight may be removed for air induction). Stock dashboard and full interior from front seats forward is required (both front seats are required). Aftermarket interior and seats are permitted.
Transmission: OEM transmission from the same manufacturer as car is required. Aftermarket transmissions are prohibited.
Fuel: Gasoline only permitted. OEM functional gas tank must be used (4-cylinder cars only may use fuels cells) Modifications to sump area permitted on all cars.
2-rotor cars:
· Manual Transmission Cars: Limited to a 78mm single turbo or 58mm twin turbos. Air to air intercoolers only. May be combined with Nitrous oxide.
· Automatic Transmission Cars: Limited to a 76mm single turbo or 58mm twin turbos. Air to air intercoolers only. May be combined with Nitrous oxide.
· RWD cars are limited to a maximum size of 26.0” x 10.5” slick or DOT slick, or any size DOT radial tire.
4-cylinder cars:
· Manual Transmission Cars: Limited to a 72mm single turbo. Air to air intercoolers only. May be combined with Nitrous oxide.
· Automatic Transmission Cars: Limited to a 71mm single turbo. Any type intercooler permitted. Cannot be combined with nitrous oxide. (A 72mm maximum sized turbo and nitrous oxide is permitted for vehicles with an OEM automatic transmission for engine used).
· FWD cars are limited to a maximum size of 25.0” x 9” slick or DOT slick, or any size DOT radial tire.
6-cylinder cars:
True Street
$800 Winner
$300 Runner-Up
$50 Semis
Entry Fee - $40
(Your car must run 12.99 or quicker and legal with the rules below to try and qualifying for this class.)
2-rotor cars:
· Manual Transmission Cars: Limited to a 72mm single turbo or 56mm twin turbos. Air to air intercoolers only. Nitrous oxide is prohibited.
· Automatic Transmission Cars: Limited to a 67mm single turbo or 56mm twin turbos. Air to air intercoolers only. Nitrous oxide is prohibited.
4-cylinder cars:
· Manual Transmission Cars: Limited to a 67mm single turbo. Air to air intercoolers only. Nitrous oxide is prohibited.
· Automatic Transmission Cars: Limited to a 62mm single turbo. Air to air intercoolers only. Nitrous oxide is prohibited.
· AWD cars are limited to DOT radial tires only.
6-cylinder cars:
All-Motor Street
$600 Winner
$200 Runner-Up
$50 Semis
Entry Fee - $40
(Your car must run 13.99 or quicker and legal with the rules below to try and qualifying for this class.)
Exhaust: Muffler(s) are required.
Driveline: Cars originally equipped to independent rear suspension must remain independent rear suspension (IRS conversions to straight rear axle are prohibited). Aftermarket axles, gear ratios, spools, and positive traction differentials are permitted.
Fuel: Gasoline only permitted. OEM functional gas tank must be used. Modifications to the sump area are permitted.
2-rotor cars:
· 2-rotor cars are not permitted.
4-cylinder cars:
· Engine must be EFI. Any style intake is permitted (individual throttle bodies not permitted).
· Motor swaps to bigger motors are permitted.
· Power adders are prohibited.
· All cars are limited to a maximum size of 25.0” x 9” slick or DOT slick, or any size DOT radial tire.
· Minimum Weight: B series and other series motors (2100 lbs) Minimum weights will be checked at random times during the event.
· Minimum Weight: K series motors (2300 lbs) Minimum weights will be checked at random times during the event.
6-cylinder cars:
· Minimum Weight: All series motors (2100 lbs) Minimum weights will be checked at random times during the event.
Street Stock
$400 Winner
$200 Runner-Up
$50 Semis
Entry Fee - $40
(Your car must run 14.99 or quicker and legal with the rules below to try and qualifying for this class.)
2-rotor cars:
· No motor swaps allowed. Engine and cylinder head must have been available for year make and model of car sold in USA.
4-cylinder cars:
6-cylinder cars:
Street ET
$500 Winner
$200 Runner-Up
$50 Semis
Entry Fee - $30
(Open to street cars of any ET.)
Race Format: ET Bracket racing. Will be run on a .500 full tree.
Body: Any year vehicles are allowed.
Suspension: Stock type suspension cars only. Wheelie bars are prohibited.
Exhaust: Muffler(s) are required unless turbocharged.
Tires: DOT radial tires, slicks, or DOT slicks are permitted of any size.
Electronics: Two-steps are permitted on manual transmission cars only. Delay boxes, transbrakes, and air shifters are prohibited.
2-rotor cars:
· Any power adders are permitted.
· All cars are permitted to run any size slick or DOT slick, or any size DOT radial tire.
4-cylinder cars:
6-cylinder cars:
Streetbike ET
$200 Winner
$100 Runner-Up
$50 Semis
Entry Fee - $30
(Open to street bikes of any ET.)
Body: Any type streetbike
Suspension: Wheelie bars are prohibited.
Street Equipment: Headlight and brake light is required.
Exhaust: Muffler is not required.
Electronics: Delay boxes are prohibited.
2-cylinder bikes:
· DOT radial tires only are permitted. .
4-cylinder bikes:
Modified by Jason Miller at 3:50 PM 8/5/2008
Old Aug 5, 2008 | 01:18 PM
2fastGSR's Avatar
King of the One Liners
Default Re: IMSTAR Rules (September 7, 2008) at MIR (Jason Miller)
Those payouts look very good for something you just put together ! !
Thank you for your efforts sir
Old Aug 5, 2008 | 01:23 PM
Thank you, and please pass the word. We need everyone's support more than ever to get compact racing back like it used to be. I am going to be knocking out a flyer tommorrow and getting them printed too.
Old Aug 5, 2008 | 01:30 PM
2fastGSR's Avatar
Default Re: (Jason Miller)
if you would like to send me some i will make sure they are on the counter of a few of the south jersey speed shops . . .
Old Aug 5, 2008 | 01:31 PM
Turbo-charged's Avatar
uh oh 26's!
as i said in the other thread...its SUPER important that everybody gets together anybody and everybody they have ever met to go to this event!!!! bring your friends, familes, cars, and whatever else! it would be really awesome for everybody if this turns into a local series next year!
Old Aug 5, 2008 | 01:33 PM
NAH2B's Avatar
looks good
cant wait for this event, i believe it will have a great turnout.
Old Aug 5, 2008 | 01:36 PM
nonvtecallmotor's Avatar
Old Aug 5, 2008 | 01:43 PM
Allan DP's Avatar
Default Re: (Turbo-charged)
we r gonna try to bring a a couple cars from the nj/ny area it should be very interesting u maryland/va boys got some fast cars out there we cant wait
Old Aug 5, 2008 | 01:46 PM
BIGTUNA's Avatar
Default Re: (dynamicperformance1llc)
Old Aug 5, 2008 | 02:20 PM
HR-1320's Avatar
Default Re:
I thought Jason said Hotrod cars had a class to race in when he first posted about this.
Old Aug 5, 2008 | 02:25 PM
Well they may fit into Street Fighter without wheelie bars. If they have the headlight decals and such. But we want this class to be a high 8 sec - low 9 sec class pretty much
Old Aug 5, 2008 | 02:28 PM
Chris99SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason Miller &raquo;</TD></TR><TR><TD CLASS="quote">Thank you, and please pass the word. We need everyone's support more than ever to get compact racing back like it used to be. I am going to be knocking out a flyer tommorrow and getting them printed too.</TD></TR></TABLE>
Cant wait for this event. Ill pass out flyers as well to the locals.
And I sent you a quick PM with a question about the rules. Thanks.
Old Aug 5, 2008 | 02:30 PM
HR-1320's Avatar
No wheelie bars or one piece frontend, Nevermind. Its great your putting on an event though. Goodluck
Old Aug 5, 2008 | 02:50 PM
toubaby2's Avatar
Default Re: Re: (HR-1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HR-1320 &raquo;</TD></TR><TR><TD CLASS="quote">I thought Jason said Hotrod cars had a class to race in when he first posted about this. </TD></TR></TABLE>
Well I can't believe this is the first class that I will fit in. At least NHRA will let everyone else in their classes except me with the lone AWD hot rod car. Not that my car has ever been competitive with the rest of the cars in my class. I may not win many but I sure do have fun losing. LOL
THANK YOU JASON
Old Aug 5, 2008 | 02:52 PM
toubaby2,
Does your car fit into Street Fighter? How fast do you run?
Old Aug 5, 2008 | 02:56 PM
E-Town4229's Avatar
Default Re: (rota92)
these events are intended for street cars thats why the rules are the way they are. although after talking with a pro recently we agreed that for these events inviting some pros out for some grudge racing would be a great attraction and something to really get the fans excited. with all the big name pros in this area its a no brainer for both parties.
-Roger
Old Aug 5, 2008 | 03:01 PM
Thats correct, we are really trying to keep the sport about the street cars, and not divide it up into too many pieces as far as classes. And have the look of how things began many years ago.
Old Aug 5, 2008 | 03:09 PM
MARC P's Avatar
Default Re: IMSTAR Rules (2fastGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR &raquo;</TD></TR><TR><TD CLASS="quote">Those payouts look very good for something you just put together ! !
Thank you for your efforts sir</TD></TR></TABLE>
Yeah payouts look good, but also looks like Tim will have to add 300 lbs to his car lol. 2300 lbs for a K
Marc P
Old Aug 5, 2008 | 03:15 PM
toubaby2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason Miller &raquo;</TD></TR><TR><TD CLASS="quote">toubaby2,
Does your car fit into Street Fighter? How fast do you run?</TD></TR></TABLE>
It looks like my car will meet all of the rules for street fighter.
At the BOTI @ MIR we went 12's and broke a rear and 2nd gear. At the Pan-Ams we got some things figured out and went 10.23 with nitrous and then went 9.91 without nitrous.
Old Aug 5, 2008 | 03:31 PM
MARC P's Avatar
Default Re: (toubaby2)
ALL Motor:
4-cylinder cars:
· Engine must be EFI. Any style intake is permitted (individual throttle bodies not permitted).· Motor swaps to bigger motors are permitted.
So why no ITB and why so heavy for K-Series?
Marc P
Old Aug 5, 2008 | 04:27 PM
Default Re: (MARC P)
probably so the b series cars have a chance
Old Aug 5, 2008 | 04:37 PM
NAH2B's Avatar
who will show up to race a lightweight k series car?
gotta keep it fair for these events to suceed
back in the day the lanes were filled and it would be awesome to see it like that again
Old Aug 5, 2008 | 04:41 PM
MARC P's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">probably so the b series cars have a chance </TD></TR></TABLE>
Hatcher is going 11.2 I think he has a chance, I bet he is #1 or 2 quailifier because of the weight penalty for K. But I'm not complaining or making excuses because I won't be there
Marc P
Old Aug 5, 2008 | 04:47 PM
NAH2B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MARC P &raquo;</TD></TR><TR><TD CLASS="quote">
Marc P</TD></TR></TABLE>
yeah but how many other b series cars are running that quick?
this is why its a good idea to have a 2nd class w/ an index. so the average racer will come out and have a chance, and the big dogs can still run their et's w/o complaining about weight penalties and such. otherwise the same cars will continue to race each other and the lanes will never be full.
Old Aug 5, 2008 | 04:48 PM
thats one car....and your still doubting him being number 1 qualifier with the weight penalty......i think you pretty much answered your own question
of all of the events ive been to over the years it seems Jason has always done the best job at making a rule book that makes the event better...and he does his homework before the rule book comes out. truthfully i think the weight penalty is perfect for leveling out the field. truthfully, as a spectator, im extremely excited to see how things pan out in the all motor class now!
