SI IdLE PRoBlem!!!!!
Old Aug 5, 2008 | 08:16 AM
doeboi365's Avatar
Default SI IdLE PRoBlem!!!!!
here this is not my car but it doing exactly the same thing wat my car is doing
http://www.youtube.com/watch?v...lated
Old Aug 5, 2008 | 08:19 AM
blkegcoupe's Avatar
From: ....................................................................................................
link doesn't take you to the right place
Old Aug 5, 2008 | 08:20 AM
JdelMsolG's Avatar
Default Re: (blkegcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkegcoupe &raquo;</TD></TR><TR><TD CLASS="quote">link doesn't take you to the right place</TD></TR></TABLE>
x2
Old Aug 5, 2008 | 08:21 AM
doeboi365's Avatar
Default Re: (JdelMsolG)
ohhh my bad bro...
Old Aug 5, 2008 | 08:44 AM
JdelMsolG's Avatar
Default Re: (doeboi365)
well if its doing the EXACT same thing, then try to replacing or cleaning up your tps.
Old Aug 5, 2008 | 08:48 AM
robfrmny21's Avatar
says video no longer avaible
Old Aug 5, 2008 | 08:55 AM
Mikej425's Avatar
yeah if it's identical to the problem in the video, like the title of the video says it would be a tps problem.
hope you figure it out
Old Aug 5, 2008 | 09:39 AM
AnotherSI's Avatar
Default Re: SI IdLE PRoBlem!!!!! (doeboi365)
do you have a check engine light also? if so what code is it? my em1 had the same bouncin idle problem at during light throttle application. wasnt tps tho, faulty iacv. cleaning it didnt help, failed internally so i replaced it and alls good.
Old Aug 5, 2008 | 08:16 PM
doeboi365's Avatar
Default Re: SI IdLE PRoBlem!!!!! (AnotherSI)
i dont have the code on me but the guy came up with two of them it was the knock sensor and my cat and i changed and reset the iacv valve... plzzz help!!!!
MeCrObS
Apr 21, 2012 08:58 AM
Fighterinsnatch
Aug 29, 2008 01:34 PM
Santys EK
Aug 14, 2006 07:16 PM
alupso
17
Apr 18, 2006 07:21 PM
matt j
Jan 2, 2004 07:21 AM
