Ls-Vtec turbo To slow on the 1/8 ???
Old Aug 5, 2008 | 12:14 AM
supabang's Avatar
Default Ls-Vtec turbo To slow on the 1/8 ???
This is my 2ed time hitting the 1/8 and I'm not happy with my times.
engine: Ls-vtec with gsr tranny @ 10psi
dyno :280whp and 195 torque
rubber: Falken azenis-615 (205/55/14)
here's one of the slips i found
r/t .900
60' 2.297
330 6.297
1/8 9.297
mph 81.87
best time was 9.226 and best trap was 84.35mph. I did a total of 4 runs.
Runs were done at 1400rpm launch. and not floored during 1st gear. Is it me or are street tires just not enough? I know they break loose super easy since i can do it all day on the street while rolling but is it that bad or am i doing something wrong? I was advised at the track to launch higher since i'm a turbo honda. I fully spool at 5300rpm so i tried to launch at 4200rpm. That was a big NO GO. I spun thru 1st-2ed-3rd and into 4th gear. Help me out. i'm tired of seeing 9's in the 8th.
ps. my current best et on 1/4 is 13.35 and my best trap is 110mph
Old Aug 6, 2008 | 06:02 AM
aztecracer1's Avatar
Default Re: Ls-Vtec turbo To slow on the 1/8 ??? (supabang)
I ran a 8.13 with a 1.9 60 foot at the 1/8 mile track in a b16 turbo with 22/8/15 slicks. Hp is right at 300 hp, car is a full interior 90 4dr. Get some slicks or drag radials and that 60' foot will drop.
Old Aug 6, 2008 | 06:41 AM
khrys771's Avatar
i ran an 8.49 @88.62 with a 2.18 60ft. i have 195/50/15" toyo proxes 4 tires, and stock suspension on my 92 civic cx, it has an lsvtec turbo also.
i launced it right at 4000 on that run, i am also using a 6 puck sprung clutch.
my 1/4 mile was a 12.84 @113.62.
Old Aug 6, 2008 | 08:32 AM
nsxmatt's Avatar
81mph is not close to 280whp in a EG hatch. I trapped 94 with around 250whp in a VX hatch and ran 7.4's. Granted it was on slicks but still your traps are low.
Old Aug 6, 2008 | 08:38 AM
khrys771's Avatar
Default Re: Ls-Vtec turbo To slow on the 1/8 ??? (nsxmatt)
i know that 1/4 mile 113mph for my weight in my civic (2450lbs) is about 265whp - 270 ish. i only spun 1st and 2nd gear.
Old Aug 6, 2008 | 09:54 AM
Sr420Det's Avatar
That to me seems about right. Yeah street tire are going to do you no justice what so ever. I bet you were spinning through the traps werent you. I had a turbo b16 and I ran 9.2 at 88mph but it would spin the entire run.
1qkfodo
Dec 23, 2008 06:08 PM
HamiltonRex
Jul 17, 2006 09:08 PM
kameleon23
Apr 26, 2006 10:47 AM
austrian type-R
Jun 17, 2002 02:28 PM
HX_Guy
Sep 7, 2001 11:45 AM
