Trans fluid drain/flush?
Old Aug 4, 2008 | 08:29 PM
JerseyJohnny's Avatar
Default Trans fluid drain/flush?
Should I just drain and fill the fluid, or should I get a "flush" from Honda? I have 187,000+ miles on 95 Accord EX, and I have heard a power flush is not good for these high mileage cars. To be honest, I don't like the idea of shooting pressure through a transmission this old anyway.
So should I do a drain and fill myself?? I know it only replaces part of the fluid that's in there (30 or 40%??) but I figure if I do it a few times I can get a lot of the old stuff out, even if not all of it. Then if I add some Lubegard ATF conditioner it can condition any of the old stuff that's in there. Does that sound like a decent plan?
It's been 2 years since I had the tranny fluid changed, about 35,000 miles. Never had a problem with my transmission. The last time I changed it was because I replaced the radiator and lost so much transmission fluid that I just drained it and refilled it.
The car is OK, the trans is fine but shifting a LITTLE rough once in a while, for the past couple of months. Might be normal, might be the very beginnings of a problem, but I'm probably just being paranoid. Personally, I think the tranny fluid is breaking down from the heat, it's been a hot summer and probably running hotter than usual. The fluid's still nice and red and doesn't smell "burnt" at all.
I saw that Lubegard makes a "flush" product - is that worth using? I would add some in and shift through the gears and run the car for about 5 minutes, and then drain it.
Also, I'm thinking of putting in Lubegard ATF protectant in when I do the refill. Is that a bad idea? It seems to be unlike other additives where it won't harm the trans or the fluid, but conditions it instead. By the way, I always use only Honda ATF, which I buy from the dealership.
Any advice would be greatly appreciated!
Old Aug 5, 2008 | 08:39 PM
mongtite's Avatar
Default Re: Trans fluid drain/flush? (JerseyJohnny)
the honda guys should be able to tell you how it's done.
Old Aug 5, 2008 | 09:43 PM
guymontag's Avatar
Maybe a flush additive could help clean things out, but I doubt any additive would improve on Honda ATF for regular use.
I think you're probably being paranoid. If the transmission is fine, it's fine. If it's going south, it's going south, and there's not a lot that you can do to alter that besides maintaining a reasonable ATF change interval.
Old Aug 6, 2008 | 06:44 AM
Turbowa's Avatar
Default Re: (guymontag)
DO NOT FLUSH YOUR TRANNY!!! This is asking for problems. Just drain and refill. If it still looks to be a little dis-colored or dark, change it at your next oil change. I have seen many a honda trannys fail because some one said to flush it. Most cars its not a problem and will work fine. But on hondas it has a tendance to wash and even tear off the clutch facing material.
Old Aug 6, 2008 | 07:09 AM
djkurious's Avatar
+1 on drain and fill. Solved my hard shifting issues.
Old Aug 6, 2008 | 08:44 AM
fit4jenn's Avatar
all honda does to flush the trans, is cycle fresh fluid after a couple of shifts, they use about 12 qts. i would drain and fill every 15000 mi, for a high mileage trans.
cabtank@aol.com
Jun 11, 2019 08:37 AM
bemused
Jul 25, 2013 06:27 AM
onda22
Oct 31, 2011 06:33 PM
dan_g
27
Oct 5, 2009 03:06 AM
Arkiados
Mar 16, 2007 10:47 AM
