white smoke off the exhaust / temp gauge issue...
Old Aug 4, 2008 | 07:24 PM
jaydem7's Avatar
Default white smoke off the exhaust / temp gauge issue...
k guys, first off i got a 96 integra ls, all stock.. car runs great with no problem. i noticed *white smoke coming out when i got my smog. failed at first, but second try, finally passed. what could it be?
also, my temp gauge is acting weird on me.. when warmed up, the needle begins to rise and stay in the middle like its suppose to, but when im on the freeway, the needle begins to point to COLD? keep in mind that there is no check engine light.
just a recap.... little white smoke coming out of the exhaust and lastly, weird temp gauge needle pointing to COLD when on the freeway..
but yeah.. any helpful input is greatly appreciated!!
Old Aug 4, 2008 | 09:59 PM
ddtfrom626's Avatar
Default Re: white smoke off the exhaust / temp gauge issue... (jaydem7)
Im not sure about your temp gauge. but white smoke means your burning a liquid most likely water or coolent. So you should check your coolant see if your burning any. Also check your oil for discoloration like milky or something.
Old Aug 5, 2008 | 03:23 AM
fin781's Avatar
Default Re: white smoke off the exhaust / temp gauge issue... (ddtfrom626)
your temp guage could be broken. mine did the same thing, never fixed it find a junker sensor and replace it and check the wire leads. turn your car on and open the radiator cap, be careful, look for bubbles coming up from the radiator, sometimes theyll carry smoke out with them, or exessive bubbles, meaning coolant is getting out somewhere.
crist488
Dec 10, 2009 06:54 AM
HONDRETTI
Feb 20, 2009 08:50 AM
accord_raffi
Aug 20, 2008 02:11 PM
leinadmiih00
Feb 21, 2007 03:08 PM
Bond
12
Oct 18, 2005 07:09 PM
