2.5 in drop problem?
Old Aug 4, 2008 | 04:34 PM
journeyquest's Avatar
Default 2.5 in drop problem?
i have 13s(stock tires) on my crx dx and have 2.5 drop coils front and back. will i have a problem w/this combo? it sits high now. whats w/ the camber kits for crxs? thanks
Old Aug 4, 2008 | 06:34 PM
vtecb18c's Avatar
Default Re: 2.5 in drop problem? (journeyquest)
yon have 2.5 springs pr adjustable coils?? you wont have any problems with 13" rims with any suspension as far as rubbing wise...camber kits come into play when you install your kit and if the front or rear tires are angles in or out...if they are than you need a camber kit to stop uneven tire wear
Old Aug 4, 2008 | 06:43 PM
Phatwhippin_CRX's Avatar
yeah you shouldn't have any problems with rubbing whatsoever. Heck, you can take it a little more than 3" or so with 14s on there, I'm pretty sure.
That low though, I'd be keepign an eye on camber, like stated above. Uneven tire wear = poop.
Old Aug 4, 2008 | 08:00 PM
Default Re: 2.5 in drop problem? (Phatwhippin_CRX)
not adjustable not yet installed. plan to upgrade to 15s later. but afraid w/ these little 13s it will be too close to the ground. not building a race car (have a chevelle 4 that) just dont want bone stock. thanks
Old Aug 5, 2008 | 09:41 AM
vtecb18c's Avatar
2.5 should be fine i wouldnt go any lower until you get your 15s
d17civic
Honda Civic (2001 - 2005)
Aug 21, 2008 05:32 PM
danyerudono
14
Aug 24, 2004 06:39 AM
90SICRX
Apr 15, 2004 10:51 AM
iridebiketrials
Mar 30, 2004 10:06 PM
ayacht
Oct 11, 2002 07:09 AM
