H22A FUEL PRESSURE AND IDLE CONCERN
Old Aug 4, 2008 | 04:18 PM
lilcowboy1984's Avatar
Default H22A FUEL PRESSURE AND IDLE CONCERN
I put a H22A 92-95 in my 1996 accord. I installed a skunk2 pro series intake manifold and 68mm throttle body, also I installed a AEM fuel rail, which i put a fuel pressure guage on. the problem is that when i start the car it idles low between 600-400 and shakes and wants to die, sometimes accomplishing that and needing a restart. if i turn on the air conditioner it really makes it drop and shake. I looked at the fuel pressure guage and it is reading 20-24psi at idle ? is that normal? i thought fuel psi should be like at 37- 41 psi. is this due to a stock accord fuel pump and the larger injectors on the h22? and could this be why the car idles low?
Old Aug 4, 2008 | 04:28 PM
autoluder's Avatar
Default Re: H22A FUEL PRESSURE AND IDLE CONCERN (lilcowboy1984)
could be where you have your idle set at.
Old Aug 5, 2008 | 09:46 AM
f22builder's Avatar
Take the vacuum line off the FPR and see if that increases your Fuel PSI (you said you had a guage) I know my FPR PSI is around 42 on vacuum and 45ish no vacuum. You may have gotten a bad FPR.
The fuel pump should be more then enough for a stock engine. But I would test to make sure the voltage is correct on the pump to rule it out.
Are you using a h22 ECU?
Correct me if I am wrong but does modifying your Fuel system require any kind of tuning? I know with injectors it does (most of the time).
GL
Old Aug 20, 2008 | 12:14 AM
I went out and started it up and it goes to 26psi and once i pul the vacuum off the regulator it goes up to 38psi. i think the vacuum lines are jacked up.
GsrIntegra789
Engine Management and Tuning
Jun 9, 2008 08:34 PM
Tchleung
Oct 18, 2004 01:48 PM
DropSquadCivic
Oct 19, 2003 03:21 PM
s o h c
Jun 5, 2003 07:49 PM
Frcfedintegra
Mar 20, 2002 09:32 AM
