converting h22a1 to a 96 prelude f22b obd2
https://honda-tech.com/zerothread?id=1053816
Took me all of 45 seconds to find.
BTW, read the top stickied threads because I KNOW you're going to be back in a few days with questions that were already answered.
https://honda-tech.com/zerothread/2168311
read the faq dude, if you cannot comprehend WAT you read , then you probably need to just take it to a competent shop that has done Honda engine swaps. While your situation is slightly more difficult, it is not impossible. Your car being a 96 means is it OBD2, so you will need a conversion harness that will plug in between you current harness and the P28 ECU.WAT year is your engine? You
would be better off with a P13 which is designed to run the H22. Your car may need a wire run for the knock sensor too because the F22 does not have one. There are probably a few =more issues that I am not aware of because my car is a 92 and is OBD1. If you do not know WAT that difference in OBD1 and OBD2 is, please just do us all a favor and TAKE IT TO A SHOP!!!!!
vietdragontekx
Aug 2, 2006 10:06 AM
91, 96, conversion, converting, ecu, f22b, h22a1, install, installing, jdm, obd2, odb2, prelude, swap
