need alternator, which ones can i use? for my b18
Old Aug 4, 2008 | 01:53 PM
Maxcapacity's Avatar
Default need alternator, can I use a obdo b16a one on my obd1?
My car is converted to obd1, I dont know if I can use a obd0 alternator on my obd1 setup? arent the plugs the same on the backs? will a obd0 b16 one work on my converted obd1 motor? I think I might have the old obdo on there I'm not sure though.
Please help.. need asap
Modified by Maxcapacity at 3:25 PM 8/4/2008
Old Aug 4, 2008 | 02:42 PM
redef90si's Avatar
Default Re: need alternator, can I use a obdo b16a one on my obd1? (Maxcapacity)
isn't a 93-97 del sol with a b16 obd1?just wondering if that would work?
Old Aug 4, 2008 | 02:56 PM
Default Re: need alternator, can I use a obdo b16a one on my obd1? (redef90si)
92-95 is obd1, do I have to use a b series strictly or can I use a d-series obd1?
Still need to know if the obd0 one will work? same plugs right?
Old Aug 4, 2008 | 03:52 PM
Crx Jimmy's Avatar
obdo and obd1 alternators are the same, you can use either it wont matter, you cant use a d series one though
Old Aug 4, 2008 | 08:43 PM
Slebidia's Avatar
Default Re: need alternator, can I use a obdo b16a one on my obd1? (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">obdo and obd1 alternators are the same, you can use either it wont matter, you cant use a d series one though</TD></TR></TABLE>
Actually with a little work you can.
There's also no need to dent the frame rail this way.
Old Aug 4, 2008 | 09:45 PM
Default Re: need alternator, can I use a obdo b16a one on my obd1? (Slebidia)
GENIOUS! Exclellent!
Everyone I have talked to said it would not work... I just did not know the difference. So the spacing diameter of the bolts is the only difference eh?
what an easy fix, i have a spare d series ready to go!
I am already running that same belt so I did'nt have to dent the wall, it clears by about 1/4".
Slebida!
Old Aug 5, 2008 | 02:21 AM
traxxasx's Avatar
Yea dude im running the same belt and no need to dent the frame it, some people are dumb.
Its clears about 1/2 inch.
Thats with a ls da alternator.
Old Aug 5, 2008 | 04:00 AM
IT GUY's Avatar
I've got a d series alternator I wanted to run on my b series, but the pulleys are different. There were fewer ribs on the d series. You guys have this problem?
Old Aug 5, 2008 | 12:53 PM
Default Re: need alternator, can I use a obdo b16a one on my obd1? (IT GUY)
My belt has 4 ribs for the pulley same as the b series... Maybe IT GUY yours has a d15 b7? idunno, could simply switch the pulleys for your prob...
great with the pic's though^^^, now I know exactly where to notch it so I'm not there all day scratching my head!
Old Aug 5, 2008 | 09:46 PM
Slebidia's Avatar
OBD0 D-series = 3 rib
OBD1-2 D-series = 4 rib
Civic89stdB16
Feb 23, 2008 04:32 PM
B16A CRX
Feb 5, 2007 03:52 PM
kingkong
May 9, 2005 11:19 PM
