not gettings gas in the cylinders. B16a swap on a dx rex
Old Aug 4, 2008 | 01:25 PM
InkerB2B's Avatar
Default not gettings gas in the cylinders. B16a swap on a dx rex
i been trying to turn on the car but it only starts when using starting fluid, the fuel pump works, i pulled off the hose from the gas filter, it had pressure... This happened to me with the dx engine harness and i just installed an si harness inside out, same luck... Any ideas? All the grounds seem to b in place... Thanks
Old Aug 4, 2008 | 08:32 PM
boostedblkef's Avatar
Default Re: not gettings gas in the cylinders. B16a swap on a dx rex (InkerB2B)
r you getting injector pulse ?
Old Aug 4, 2008 | 10:20 PM
Phatwhippin_CRX's Avatar
Default Re: not gettings gas in the cylinders. B16a swap on a dx rex (boostedblkef)
*dumb question*
You did convert it over to PGM-Fi, right?
Old Aug 5, 2008 | 05:44 AM
InkerB2B's Avatar
Default Re: not gettings gas in the cylinders. B16a swap on a dx rex (Phatwhippin_CRX)
jajajajajajajaja yeah i did the mpfi on the dx harness, then i changed to an si harness in and out. Its n0t electrical tho, i just found out im n0t getting gas not even in the fuel filter... I guess the lines are cloged. Anyone knows how to fix that? Thanks
Old Aug 5, 2008 | 06:19 AM
b16a1eg6's Avatar
Could be your main relay went bad.
efjones9
14
Nov 30, 2009 11:16 AM
amp244
Jun 25, 2009 08:16 AM
IHEARTMYHONDA91
Mar 14, 2008 09:55 AM
JdM_RACeR07
Oct 10, 2006 07:10 PM
Bad89rex
Apr 22, 2005 06:09 PM
