98 wiring issue
Old Aug 4, 2008 | 11:34 AM
spooled-r's Avatar
Default 98 wiring issue
allright so there is only one wire that i can find wewre it goes its yellow w red stripe. its on drivers side by oil filter and by knock sensor its not a plug but a wire that a bolt will go through my car wont start but it turns over good fuel pressure and spark and the main relay is fine will run if starter fluid is sprayed in intake so im pretty sure this wire has something to do w fuel any ideas
jest513
May 31, 2011 08:20 AM
streetracerof06
Dec 15, 2005 07:06 AM
integmester
Jul 22, 2004 04:26 AM
Rexxer
11
Jul 9, 2004 11:21 PM
