Ecu Gurus-would converting from a jdm ecu to a usdm ecu de-tune the car
If this is OBD2, and you're running a JDM motor then you will get some check engine lights, which will put your car in limp mode.
Otherwise thefre won't be a noticeable difference, as long as you're running the correct ECU.
u2civic1
Apr 1, 2003 02:44 PM
