Tire pressures...
Hey guys, I just recently purchased a set of Michelin Pilot Roads with a max cold psi of 42psi. The handling feels very different from my Supercorsa Pros that I was using. Turn in is a lot faster and twitchy. I used to run 38F/42R on the old setup. What do you guys recommend for this? I mostly do straight line riding with the occassional corner.
Should I run more in the rear than the front? Or equal? My manual says 38F/42R but I'm not sure what kind of tires came with it originally.
Thanks.
Thanks.
VTECAcuraGSR
Sep 6, 2002 08:29 AM
