ECU found...
Old Jul 22, 2002 | 08:07 AM
muskrat's Avatar
Default ECU found...
If you saw my other post you know I just bought a ZC CRX, anyway, there were some extra parts in the car, the stock cam gears, an A/C or power steering bracket, some bolts, and an ECU. I haven't looked at the numbers on it, but someone wrote on it in marker "H22A," isn't that the Prelude engine? Why would this ECU be in my car, is it a computer used with the ZC engines or was it probably just randomly thrown in there?
Justin D. Fender
Old Jul 22, 2002 | 09:00 AM
REDBARON's Avatar
Default Re: ECU found... (muskrat)
H22 is the prelude engine code, but it wouldn't be used with the ZC. Or at least to my knowledge is doesn't. What's the code on the ecu?
Old Jul 22, 2002 | 10:13 AM
Jason Mewes's Avatar
Default Re: ECU found... (REDBARON)
I think most of the H22a ECUs are P13's. It will say something like
"37820-P13-A01" . If it is in fact a Manual Trans. H22 ECU then you "found" at least $200 .
Cambo88zc
Jan 21, 2006 05:07 PM
crx5
May 4, 2005 07:31 AM
phatrick2332
Apr 29, 2004 11:33 PM
ek_99_SiR
Feb 21, 2004 02:23 PM
tdc
Feb 23, 2002 08:32 AM
