slipping clutch ???
When i stomp on the gas the rpms are climbing and i know my tires have traction but seems like my cars not moving after a certain at higher rpms, does this sound like a clutch slipping?
Now I am using stock flywheel, stock, clutch. I am running a "98 accord with a H22A4 out of '01 Prelude with 5 speed. I used to have a stage 3 ATC clutch with heavy duty pressure plate and 8lb lightened flywheel. It was just too much for my motor mounts, I was breaking them all the time, and in stop and go traffic you would have to rev pretty high to get going. When I first got that ATC clutch I was stalling all the time because that heavy duty pressure plate would just grab onto the clutch disc so quick and would not slip even a little bit.
EVOCELICA
Oct 13, 2001 11:36 PM
