Bunch of problems with 91 accord
I came back from the dealership and they gave me a list of problems.
- Right outer tie rod broken (fixed)
- Water pump is leaking with timing belt work
- Cover Gasket is leaking
- Sistribtor o-ring leak
- Right drive shaft is noisy
- front stabilizer links (loose)
- oil pan
Which ones should I get fixed?
like I don't want something to snap while i'm driving and I die..
- oil pan
My only concern is that I have no knowledge of fixing cars so, I would assume the cover gasket and o rings are not that hard to do if you have the equipment and instructions right?
I guess i'll need a list of stuff? hopefully and instructions.
I'm assuming the drive shaft is a must to replace or else the car won't run right?
Modified by mikeszutu at 9:46 PM 8/3/2008
Drive shaft = axle, I'd wait until it crapped out. Here they're like $40 at shops with a lifetime warranty.
The gasket is just remove the valve cover ~10 bolts and then pulling off the old, installing the new.
The dizzy's o ring I'm not sure on the steps to replace but shouldn't be difficult.
timing belt and cover will cost arond 120-200 bucks, but its worth it, if ur belt snap ur head of engine is done, other word means need a new engine. oil pan is like 12 little 10mm bolt, might need to drop ur exaust for oil pan to be taken out
WingedMan
Aug 30, 2011 08:03 AM
