type R lsd and gsr tranny?
Old Aug 3, 2008 | 07:48 PM
BLWNB16A@11psi's Avatar
Default type R lsd and gsr tranny?
I would like some input if the type R lsd will fit into a gsr tranny?
I think it will fit into thr SIR and LS just not completly sure if it will work in the GSR
and not change the ring gear
both trannys would be hydro
thanx in advance
Old Aug 4, 2008 | 04:25 AM
civicboy1128's Avatar
Default Re: type R lsd and gsr tranny? (BLWNB16A@11psi)
it will work with the Sir tranny but not the gsr. The final drive in the b16 and the type r are the same and the final drive in the gsr and the ls are the same. to put a type r lsd in a gsr you would have to change the final drive
Old Aug 4, 2008 | 06:05 PM
Colt Seavers's Avatar
The type r diff will go right into the gsr tranny...You just have to cut out the webbing around the area where the diff sit's
The type r diff and the b16 diff's are different size's
tuhboek
Apr 29, 2010 01:52 PM
chino369
Jul 25, 2006 02:58 PM
M u n k i
Oct 17, 2005 05:16 PM
pushinlsteg
Sep 21, 2005 03:36 PM
jonoknut
Feb 26, 2003 12:42 PM
