Possible to remove drivers side engine bracket without taking off lower timing belt cover?
Old Aug 3, 2008 | 07:30 PM
redman223's Avatar
Default Possible to remove drivers side engine bracket without taking off lower timing belt cover?
It looks like I installed the wrong engine bracket on my car. As you can see in these pics, the drivers side bracket is crooked, which leads me to believe that it is not a GSR bracket. Which bracket might it be? LS? D-series? Those would be the only ones it could be, as many brackets were lying around mixed in together and they were all GSR, LS, or D-series.
I need to take it off tomorrow and get the right one, I am wondering if it is possible to remove the bracket without taking off the lower cover?
Yes, the bolts go all the way through the bracket and are not broken or stripped out.
Old Aug 4, 2008 | 07:52 AM
redman223's Avatar
Default Re: Possible to remove drivers side engine bracket without taking off lower timing belt cover? (redm
I guess I'll find out today and let everyone know.
Old Aug 4, 2008 | 08:45 AM
JDMguy88's Avatar
ya you need the one that is straight, not diagonal
edit* I believe they are found on B16's from the em1
Old Aug 4, 2008 | 08:48 AM
redman223's Avatar
Default Re: (JDMguy88)
Thanks, I am going to take this thing off right now and will head to the junkyard right afterwards.
Old Aug 4, 2008 | 01:52 PM
redman223's Avatar
Default Re: (redman223)
Well it appears that the bracket is indeed correct, but the bolts and studs were incorrect. With tweaking, I was able to loosen the bolts, and use a pry bar to get the mount into the correct position, and then re-tighten.
Old Aug 4, 2008 | 06:11 PM
steveo135's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redman223 &raquo;</TD></TR><TR><TD CLASS="quote">Well it appears that the bracket is indeed correct, but the bolts and studs were incorrect. With tweaking, I was able to loosen the bolts, and use a pry bar to get the mount into the correct position, and then re-tighten. </TD></TR></TABLE>
but if you didnt figure it out no you cant take off the bracket without removing the cover... i learned that during my rebuild when i got the timing set all the covers on and torqued and realized i didnt install the bracket
Old Aug 4, 2008 | 06:18 PM
redman223's Avatar
Default Re: (steveo135)
I did something similar when I was putting it all together last year.
hfd36jtb
Aug 15, 2006 05:04 PM
mztykal
Honda Civic (2006 - 2015)
Apr 7, 2006 04:49 AM
Muckman
Nov 27, 2005 06:51 PM
b18_racer805
Sep 29, 2005 07:46 AM
