How to install new sunroof in 91 Civic Si?
My old sunroof is all rusted around the glass and the seals leak so it's causing rust inside my A pillars etc. I got a new sunroof glass. Any tips on installing it. I'd like to make this as painless as possible but I have a bad feeling...
Actually, I found you don't have too. There are bolts hiding under some rails under the glass. You can just unscrew and pop the glass out. 15 minute job.
take off the plastic pillars like where a gauge pod would be remove there rear view mirror, and the interior light on the celing, along with the plastic trim piece that the light is on.
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg9589 »</TD></TR><TR><TD CLASS="quote"> and should i be careful?</TD></TR></TABLE>
Hell no..Use an Axe and a machete..
But seriously,Some of the info here will probably help you:
http://wwwx.cs.unc.edu/~hays/crx/crxsunroof.pdf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">http://wwwx.cs.unc.edu/~hays/crx/crxsunroof.pdf</TD></TR></TABLE>
That link is [freak]ing awesome!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n3h3bkau »</TD></TR><TR><TD CLASS="quote">
I recommend you guys save the PDF file in case
the site becomes unavailable as it has in the past..
rewerbcrx
11
May 18, 2007 07:02 PM
jond
Aug 28, 2006 04:35 PM
nwf_snake
Apr 26, 2006 05:14 PM
