urgent cannot find the tdc marks on my crankshaft pulley
ok so i looked at my crankshaft pulley and seen no signs of marks and i pulled the head off now here is the problem how do i find tdc on cyl 1
Take the crank pulley off if you can't see it on there. The crank sprocket has a TDC line that should lines up with the tiny arrow head on the oil pump when you're @ TDC.
i found 4 notches on it but they are not color coded there is 3 close together and the to the right is another one which one is tdc
Nextelbuddy
Mar 29, 2004 11:43 AM
