LS transmission to a d16 88 crx?
I was wondering if an integra LS 5 speed would link up properly to my d16. my tranny is going bad and i need to replace it. i have heard that the ls transmissions can take a serious beating so i'd like to install that on my 88 CRX. the transmission is from an 89 LS non vtec b18 integra.
your car has a cable operating an arm for the clutch. the newer transmissions have a hydraulic slave cylinder. you need parts or a kit to convert your cable movement to operate the hydraulics
okay. that seems like a quite formidable task. So that is a lot of work to switch out. until what year was a cable used? it would just be easier to forgo the conversion and use a transmission that would bolt right up.
1990JDMCRX
Sep 4, 2009 11:26 AM
SteyrTMP
May 25, 2005 11:17 PM
88, 91, 95, b18, bolt, civic, converting, crx, d16, gears, ls, tran, tranny, transmission, transmissions
