A\C thermal protector
Will it hurt to bypass it to keep my a\c on? I've checked my wiring and made sure voltage is at the a\c connector and the compressor has a good ground but it will cut off while driving and if you accelerate hard sitting still. This is the only thing that iI haven't bypassed yet. Any advice would be appreciated.THX
I'd figure out why your AC is doing what it's doing. A lot of Hondas turn the compressor off under a high load situation so you can get the most out of all 57 hp at tap. That is controlled by the ECU. If it isn't that, figure out why the compressor is going off. Put a gauge set on it and see what the pressure is doing.
Ryan
Ryan
boredazhell20
Sep 22, 2010 01:02 PM
Civic Racer X 7
Aug 8, 2007 05:15 PM
