d15b diffrences
Old Aug 3, 2008 | 12:07 PM
zenon8890's Avatar
Default d15b diffrences
hi HT, i own a d15b obd1 engine sohc vtec and i burned my piston rings, i found a vtec-e block, will it bolt on and would it be the same?! i'm running a turbo application, i saw that the pistons on the vtec-e engine looked like low compression
Old Aug 3, 2008 | 12:56 PM
JDM_SOHC's Avatar
Default Re: d15b diffrences (zenon8890)
yup, it's a direct swap...
Old Aug 4, 2008 | 09:20 AM
zenon8890's Avatar
the vtec sohc d15b valves looks bigger than the vtec-e ones, should i change anything on the d15b vtec head to make it bolt on the vtec-e head?
Old Aug 4, 2008 | 10:21 AM
Relic1's Avatar
it's a direct swap mechanically, but it will not run the same, nor will it produce as much power.
the VTEC-e pistons have a huge dish to compensate for the low smaller combustion chamber in the head.
the dish in those pistons is too large for your head, even with a turbo application. (~7.5:1 compression)
pull the engine apart, replace the rings, and tune the car. (or you'll be burning rings again)
jordan_rael_420
Aug 2, 2010 11:51 AM
8dxhatchy8
May 30, 2009 03:24 PM
GetSTROKED
Oct 19, 2006 03:39 PM
.dave
Aug 15, 2006 07:50 PM
spun Vtec
Jan 10, 2003 09:28 AM
