Just bought a 95 Civic... oil in the overflow tank, low compression on #4, smoking bad out the back.
Old Aug 2, 2008 | 06:07 PM
92integraVTECgsr's Avatar
Default Just bought a 95 Civic... oil in the overflow tank, low compression on #4, smoking bad out the back.
Alright so I just bought a 95 Honda Civic DX (I'm assuming). It's a 5spd. It has a D16y7 engine swap and is running an automatic P28 ECU.
The thing smokes like crazy. Got home. Did a compression test and here are the results:
1 - 230
2 - 240
3 - 240
4 - 150
#4 spark plug is just completely covered with baked on oil. Spark plugs 1-3 are in perfect condition.
The coolant overflow bottle is filled with oil and coolant. There is some oil leaking out the throttle body some through the IACV (whoever did the swap, swapped out intake manifolds and surprisingly did a really good and clean job swapping it. Only thing was they didn't change the ECU's and just unplugged the CHECK ENGINE light, but they couldn't slide that by me). The only 3 codes being displayed are 2 for VTEC and 1 for the automatic transmission (P28 Auto ECU).
My questions:
1. I am assuming the head gasket is gone, would you all agree?
2. What ECU is used to run a D16y7 manual transmission? And is it OBD2? If so, what OBD1 ECU would run the engine?
Thanks
Old Aug 2, 2008 | 06:20 PM
94EG8's Avatar
Seagull Management
Default Re: Just bought a 95 Civic... oil in the overflow tank, low compression on #4, smoking bad out the b
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">
My questions:
Thanks</TD></TR></TABLE>
Yes, either that or a cracked block
That would be a P2E sir, and yes its OBD2, the closest ECU that OBD1 would be the PO6 found in the DX/LX you can add CX/EX to that list as well if your in canada. They aren't hard to find and shouldn't be worth all that much. I wouldn't be in any hurry to get rid of that P28 though, you can convert that to a 5 speed quite easily, they're also worth some money and very easy to sell if you wish to.
Old Aug 2, 2008 | 06:22 PM
-JSpecEk*9-'s Avatar
1. headgasket or rings
2. yes its obd2 and you need a jumper harness.
i have a extra ecu for a y7 man.
Old Aug 2, 2008 | 06:34 PM
Ya I will probably just end up selling the P28.
And I'm hoping its the headgasket, but yes it could be a cracked sleeve (I'm hoping not).
Old Aug 2, 2008 | 08:34 PM
CoolFoolIT
42
Jan 19, 2012 09:23 PM
The_Honda_Guy
27
Jul 5, 2011 07:11 PM
HommeDeBois
12
Mar 17, 2011 08:08 PM
The_Honda_Guy
Mar 8, 2008 08:23 AM
ealex
Mar 2, 2005 09:53 AM
