1st F22a1 Sprint Car Racing
This is our race car. I dont knoe if anybody knoe dirt track racing.Our class Sprint 100 racing association.We race at Marysville Race park next to sacramento.We built the First F22A1 came out of a 1991 Honda accord and put it on a Sprint car.Let me knoe what u guys think.....
Modified by jdmCivic925 at 10:52 PM 8/3/2008
badass, but why the A1 when you could of got a slightly more torquey F22A6? Also, why kind of ITB's are you running? or is that a carb set up as I do not see injectors or wiring for them?
did you guys make the carb setup and header for the car? or was all that stuff made at a race shop or something?
If its not top secret, whats the engine set up that you guys are using? Stock cam? pistons etc?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic »</TD></TR><TR><TD CLASS="quote">did you guys make the carb setup and header for the car? or was all that stuff made at a race shop or something?
If its not top secret, whats the engine set up that you guys are using? Stock cam? pistons etc?</TD></TR></TABLE>
We are running 4 individual throats of 40mm side draft mikuni carbs with a customized manifold using the stock flange
the header, intake manifold and all other custom parts have been built by us.
the engine is mainly composed of stock parts, arp rod bolt, acl bearings, kaizenspeed balancer shaft removal kit and a delta 272 cam with adjustable cam gear and mild port work are the only modifications to the engine.
Next season a new built motor will take its place
jdmCivic925
67
May 19, 2009 03:59 PM
