I can't quite put my finger on it but something's missing....
Just got my forks back today. FINALLY! I got a trackday on Monday at NJMP Thunderbolt.
Going outside to put the new forks on and finish buttoning everything up
haha. I've never done it before so I'm going to take my time. Will probably take me just as long to put the rear wheel on with that stupid frikin rear brake that's always a pain to fit
MORE PICTURES NOW
be sure to take pics of the process and how the bike is before the fairings go back on.
What kind of mods do you have? Other than the visible jardine pipes, sato rearsets and brembo mc?
I hate mounting the rear wheel. I think I curse more in a rear wheel change than I do in a month of normal life.
Forks: Racetech gold valve rebound and compression, Racetech top out spring, 1.0kg stock springs. Done by MRP Motorsports
Penske Rear Shock
Dan Kyle Rear Shock Link
Spiegler SS lines Front and Rear
Jardine Exhaust
PC3 USB
Dynojet Quickshifter
Sato Rearsets
Speedohealer
520 AFM -1 Front Sprocket
520 Stealth +1 Rear Sprocket
520 DID chain
K&N Filter
Brembo 19x18 Front Master Cylinder
HRC Soft Bite pads
Scotts Steering Damper
PUIG double bubble screen
Frame sliders (unknown brand)
ECU Jumper Mod
Removed Pair/Air Flapper/Left Radiator Fan
Stomp Grip
I think that's it... I have some unknown race fiberglass on there for the track with a matching tank with vortex gas cap as well. Spare set of sp2 wheels with dragon supercorsa pros mounted. Also have a wave/lightened rear brake rotor on that one as well.
Gonna head outside now...
*EDIT* Forgot the latest Mods for the forks!!
Penske Rear Shock
Jardine Exhaust
PC3 USB
Sato Rearsets
Speedohealer
520 DID chain
K&N Filter
HRC Soft Bite pads
ECU Jumper Mod
Stomp Grip
It's pretty simple. Take off the brakes, remove the wheel, remove the fender, loosen the triple clamp and clip on bolts and the forks drop out. Installation is reverse.
Race glass like mine and his come off in less than 5 min.
mine is:
Penske 3-way Rear Shock
Varium Rear Shock Link
GP Suspension fork valves and springs
Aeroquip SS lines Front and Rear
Moriwaki Exhaust
PC3R
Harris Rearsets
Speedohealer
530 AFM -1 Front Sprocket
530 Stealth +1 Rear Sprocket
530 DID chain
Carbon fiber airbox/tray
AP Racing Adjustable Ratio Front Master Cylinder
Galfer pads
Thorsten Frame sliders
ECU Jumper Mod
Thorsten Carbon Radiator Ducts
Thorsten Carbon Battery relocation bracket
Stomp Grip
Sharkskinz
Woodcraft clipons
Pretty similar
Moriwaki Exhaust
PC3R
Harris Rearsets
Speedohealer
530 DID chain
Galfer pads
ECU Jumper Mod
Stomp Grip
Sharkskinz
Woodcraft clipons
Pretty similar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdeJong 03 »</TD></TR><TR><TD CLASS="quote">oh i know how to do it i just wanted to see his goodies lol</TD></TR></TABLE>
was the rear shock worth the money?
i have the suspension tuned for my weight already (185 with gear) but ive been hearing all these things about it not being good enough.
also, was the speedohealer cheap? I have +3 in the rear on a 520 conversion and my speedo is like 10-15 mph fast depending how fast im going
the set up is done though so i may go back to stock but i like the power im getting
woah now I don't even know you
I learned that I suck at safety wiring...
On to the forks: The top out springs made my forks longer so I dropped them a line to keep it raked out for quick turn in. Now with that my shock sag is screwed up as well so I gotta redo that and the forks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu »</TD></TR><TR><TD CLASS="quote">well done... and done correctly
Thanks... If you're going to do it, I've always said do it right... I shudder to think the amount of money I've put into this thing but I have a **** eating grin on my face every time I ride it.
</TD></TR></TABLE>Thanks... If you're going to do it, I've always said do it right... I shudder to think the amount of money I've put into this thing but I have a **** eating grin on my face every time I ride it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toshiro »</TD></TR><TR><TD CLASS="quote">Is that one of those new hover bikes?</TD></TR></TABLE>
yeah it uses technology only available from aliens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EngineNoO9 »</TD></TR><TR><TD CLASS="quote">On to the forks: The top out springs made my forks longer so I dropped them a line to keep it raked out for quick turn in.</TD></TR></TABLE>
+1
I had to do this with mine as well. I knew the bike looked a little tall in the nose but I didn't realize by how much!
+1
I rode my bike to tech this morning with it dropped 2 lines.. I immediately knew it still wasn't right. Dropped it one more so 2 more from what I used to run and it worked out great:
