oil leak ahhhhhhhhhhhh
im havin this really bad oil leak in my car its a b20 vtec. when am driving all i see is white smoke from the oil burning on the exhaust and it stinks up my interior. looks like its coming from the oil filter but am not sure i changed the filter a few times and it stopped once but now its leaking again after an oil change. anyone ever had an oil leak like this?
i did on my old b16A civic. it was from the stock catchcan or w/e its call.. it wasnt bolted down right so it would leak oil and burn up on my exuahst piping that passes under the motor. i just got the right bolt and fixd it and it stopd.
Check your oil filter again. Sometimes the old o-ring will melt to the block and not come off when you remove your old filter. Then when you installed your new filter, it had two o-rings. If it is doubled, then just scrape the old one off the block and your set. I've seen it happen a few times. Good luck
