rear seats on 1990 honda civic si... HELP
how would I take off my rear seats on my ef, so far I took out the part that you sit on, and cleaned that one , but now I want to clean and wash the back part of the seat, but cant seem to get them off, I took out that few screws and bolts I found but other than that I cant seem to make them come off. would anyone have a picture where the other screws/bolts could be at ??
thanks
thanks
It's hard to explain but you know how there's basically a pin on each side that holds the seat in place? Well the outside pins have a clip on them you need to pull off. after that you should be able to wiggle the seats out. Be carfeul not to tear the fabric on the inner pins, it can be a little tight.
Ya man its really simple lol I had a hard time messing with mine there are two black plastic clips that just pull right out and you move your seat over a bit and slowly pull up and out its easy once you get it
