Is the Si (99-00) exhaust cam same as GSR (94-01)?
Old Aug 2, 2008 | 10:24 AM
sk8shorty012's Avatar
Default Is the Si (99-00) exhaust cam same as GSR (94-01)?
As the title states, i'm trying to figure out if the si (b16) exhaust cam has the same specs in terms of lift & duration as a GSR camshaft. I tried to search around, but no real definite answers.
Old Aug 2, 2008 | 11:21 AM
Old Aug 2, 2008 | 12:55 PM
Frickr's Avatar
Default Re: Is the Si (99-00) exhaust cam same as GSR (94-01)? (sk8shorty012)
Integra GS-R
Int-230 dur. / 10.6mm lift
Exh-227 dur. / 9.4mm lift
Civic Si '99 Spec
Int-240 dur. / 10.7mm lift
Integra Type-R Pre '99 Spec
Int-240 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Civic Type-R And Integra Type-R
Int-243 dur. / 11.5mm lift
Old Aug 2, 2008 | 12:59 PM
thanks!
So it seems as though they are the same afterall. Where'd you get your information from though?
edit: that's wierd though, cause according to that list the exhaust cam has a greater difference than the intake, which would make you think the exhaust cam makes the bigger difference.
Old Aug 2, 2008 | 01:16 PM
Frickr's Avatar
Default Re: (sk8shorty012)
i just searched the arcives and typed in cam specs.
Old Aug 2, 2008 | 01:18 PM
Default Re: (Frickr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">i just searched the arcives and typed in cam specs.
good looking out.
Any insight on the statement about the exhaust cam having a greater difference?
Old Aug 2, 2008 | 01:30 PM
Frickr's Avatar
im kind of thinking that it will overlap a bit more on the intake stroke so it will help draw in more air and fuel
Old Aug 2, 2008 | 02:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">im kind of thinking that it will overlap a bit more on the intake stroke so it will help draw in more air and fuel</TD></TR></TABLE>
so, in your opinion would it be best to get both cams or just the intake?
It will be on a boosted si, btw.
Old Aug 2, 2008 | 03:01 PM
Frickr's Avatar
i would get the ctr cams myself. but the stock b16 cams will be just fine
Old Aug 3, 2008 | 10:48 AM
thanks. Any other opinions?
thevtecnician
Apr 16, 2017 09:05 AM
Black93si
Nov 10, 2009 10:47 PM
darrinbrewer
Jan 18, 2003 08:44 AM
Qwikrex
Dec 2, 2002 03:27 PM
JDMCRX
Jun 10, 2002 02:30 PM
