Engine block cleaning
Old Jul 22, 2002 | 05:02 AM
brasilracing's Avatar
Default Engine block cleaning
What substance do you use to clean an engine block? When I purchased my engine, it was not pressure cleaned and it looks gritty (saltwater from shipping?) from something.
Thanks
Old Jul 22, 2002 | 07:28 AM
thinkbrianthink bu's Avatar
Default Re: Engine block cleaning (brasilracing)
Just depends on what kind of 'dirty' it is. If its just dirt/grease/gunk you can use simple green which most ppl will suggest. If its somthing a little harder to clean you might want to consider stripping the block down and take it to get sandblasted.
Old Jul 22, 2002 | 07:48 AM
BROOD's Avatar
Default Re: Engine block cleaning (C5_ALLMOTOR)
Castrol Superclean cleaner/degreaser and a brush has always worked well for me
Old Jul 22, 2002 | 07:49 AM
.nate's Avatar
Default Re: Engine block cleaning (SLPR)
Carb Cleaner
Old Jul 22, 2002 | 09:01 AM
Hayasa15's Avatar
Default Re: Engine block cleaning (N8)
oh yeah simple green
Old Jul 22, 2002 | 09:09 AM
teeter7467's Avatar
Default Re: Engine block cleaning (Hayasa15)
if it is just a block(no pistons, crank, etc...) hot tank it. not only does it clean the outside it gets inside too. Its not too expensive.
Old Jul 22, 2002 | 09:25 AM
Ceeveek's Avatar
New User
Default Re: Engine block cleaning (teeter7467)
be careful with the Castrol product. I have some nice stain marks on my intake from when i used it to clean my valve cover. I guess some had splashed on the intake and it did some damage
Old Jul 22, 2002 | 11:03 AM
Thanks for the responses. It's not from grease or anything rather some sort of grayish oxidation on the block. I don't know what it is, but it needs to come off, makes the block/intake manifold look like ****.
Old Jul 22, 2002 | 11:06 AM
4g4me's Avatar
I know this may sound dumb, but I had the same **** on my motor. What I did was use simple green to get all the road grime and oil off the block and painted it a 1500 high heat aluminum paint. Thing looked pretty good, if you like a shiny block.
My$.02
Old Jul 22, 2002 | 11:20 AM
BROOD's Avatar
Try Castrol Superclean wheel cleaner. I used that wheel cleaner and a brush once on some oxidized Aluminum parts. It worked out farily well.
Old Jul 22, 2002 | 01:02 PM
Evs-One's Avatar
Solbros Owns Me
it never fails to pressure wash too!! One of my favorite tools!!
crx_saru
Nov 20, 2009 03:58 PM
tootybaby
19
Sep 21, 2009 03:23 PM
the DA in HONDA
Oct 21, 2004 04:59 PM
92DSeries
10
Jan 15, 2004 04:01 AM
wtf
Aug 24, 2002 08:14 PM
