93 ACCORD Fuel Pump Location
Old Aug 2, 2008 | 05:58 AM
moo32moo32's Avatar
Default 93 ACCORD Fuel Pump Location
93 Honda Accord 4 Door Lx
I need to change Fuel Pump and have checked the Hayes Manual and it states that it is in gas tank. And that I need to remove the gas tank.
I have had people tell me that there is an access panel underneath the back seat. Is there anyone that knows if this is true?
Old Aug 2, 2008 | 08:00 AM
Mr Yamada's Avatar
Default Re: 93 ACCORD Fuel Pump Location (moo32moo32)
The way to find out if you have to drop the tank, is to look for a round access panel behind the rear seat in the trunk floor.
I believe the fuel level sending unit is on the pssenger side and IF there is an access panel on the drivers side it will be for the fuel pump.
Old Aug 2, 2008 | 08:21 AM
MenaceAccord92's Avatar
You must drop the tank to change the fuel pump. There is an access panel, but not big enough to remove the fuel pump. To do that, you must cut/enlarge that hole.
Old Aug 2, 2008 | 09:06 AM
moo32moo32's Avatar
Default Re: 93 ACCORD Fuel Pump Location (MenaceAccord92)
Any idea what the access panel is for if the pump wont fit through it?
Old Aug 2, 2008 | 07:50 PM
JDM_DC4_Fanatic's Avatar
its so you can unplug the fuel pump and see if its getting power if it ever needs to be serviced.
Old Aug 11, 2008 | 12:38 PM
moo32moo32's Avatar
Default Re: 93 ACCORD Fuel Pump Location (JDM_DC4_Fanatic)
Thanks to all for your comments. I believe I have a Main relay problem, hopefully it is not fuel pump.
podom
Mar 17, 2016 06:46 PM
ULNAFARKIN
Jul 19, 2015 02:49 AM
Kwish
Classic Hondas
Apr 23, 2012 01:01 PM
ahondaowner
Dec 31, 2008 09:48 AM
94teggyls
Jun 14, 2003 09:01 PM
