Energy Suspension Motor Mount inserts
Old Jul 22, 2002 | 04:52 AM
m0t0rhead's Avatar
Default Energy Suspension Motor Mount inserts
How many of you have motor mount inserts installed ? And which ones... front, rear, driver's side ???
What are your experiences with them installed ? In contrast to stock ones ?
any problems or complaints ?
I'm scheduled to have them all installed... and would like some insight before i take the plunge. I HAVE heard some bad things about them... like toooo much vibration.
Please clarify!
Old Jul 22, 2002 | 06:26 AM
m0t0rhead's Avatar
Default Re: Energy Suspension Motor Mount inserts (Escobar)
OMG.
Does anyone have motor mount inserts ????
Old Jul 22, 2002 | 06:38 AM
smokin rubber's Avatar
I have the front insert. Only down side is that you also need to buy a new stock motor mount.
Old Jul 22, 2002 | 02:18 PM
TypeSH's Avatar
Default Re: Energy Suspension Motor Mount inserts (smokin rubber)
can you elaborate on this? I thought they were just inserts fo the existing mounts?
Old Jul 22, 2002 | 02:25 PM
Nick M's Avatar
Mine went right into my front mount, it was out of the car of course during my swap.
Old Jul 22, 2002 | 03:09 PM
Default Re: Energy Suspension Motor Mount inserts (TypeSH)
I could have just reuased the old mount, but it was torn to hell and the ES directions say "If the mount is severly damaged, we recommends replacing with a new engine mount".
Old Jul 23, 2002 | 04:28 AM
m0t0rhead's Avatar
WOW. No one has answered my questions.
I hope there's someone knowledgable in here......
this is not looking good.
Old Jul 23, 2002 | 06:05 AM
Boosthead's Avatar
They sell a front mount insert?? When I ordered mine, I was told it was just the rear, which is whatg I received. Mine is a 91'
Old Jul 23, 2002 | 08:28 AM
4doorH22's Avatar
I guess you are having the front and rear 5th gen inserts installed.
E/S only makes a front mount for the 4th gen, which I have. Just this one front mount added a good bit of engine vibration to the cockpit, but not too much to be annoying.
I'll eventually upgrade to a rear Prelude motor mount and insert which should be comparable to your setup and expect NVH levels to be only barely tolerable.
Old Dec 27, 2002 | 04:23 PM
cyrixvsp2's Avatar
Default Re: Energy Suspension Motor Mount inserts (4doorH22)
so this adds vibs to the car? i thought replacing it was suppose to reduce vibrations.
and i want to change the rear one on my sis's motor and the manual doesn't say. anyone want to help?
Old Dec 27, 2002 | 06:15 PM
dvp95's Avatar
Default Re: Energy Suspension Motor Mount inserts (cyrixvsp2)
I have just the front tranny insert on my h22a. Yes it does add vibration to the car because the point of it is to reduce the movement of the engine which would transfer the vibration to the car. It vibrates most at idle and when you're are just accelerating.
Old Dec 28, 2002 | 02:41 AM
niedejb's Avatar
Default Re: Energy Suspension Motor Mount inserts (dvp95)
I have the accord inserts on my car. I had to modify the rear inserts to fit since its a CL.
http://home.insightbb.com/~niedejb/mount2.html
[Modified by niedejb, 5:41 AM 12/28/2002]
[Modified by niedejb, 5:42 AM 12/28/2002]
Old Dec 28, 2002 | 07:39 AM
clonephoon's Avatar
Default Re: Energy Suspension Motor Mount inserts (niedejb)
Are those energy suspension inserts? Energy Suspension says they only supply one torque position does this mean they supply both the front and rear insert and call the rear one the torque position? http://www.suspension.com/honda.htm
Old Dec 28, 2002 | 07:50 AM
Nick M's Avatar
Default Re: Energy Suspension Motor Mount inserts (clonephoon)
ES only makes a front insert for 5th gen accords.
Old Dec 28, 2002 | 08:55 AM
niedejb's Avatar
Default Re: Energy Suspension Motor Mount inserts (Nick M)
Mine are prothane (I think).
This is what I got from the accordstore.
94-97 4cyl POLYURETHANE ENGINE MOUNT INSERTS
431907 | $24.95 | QTY: 1
Old Dec 28, 2002 | 10:18 AM
4doorH22's Avatar
Sorry for bad pics.
Stock 4th gen EX rear mount on left (4th and 5th gen EX mounts are very similar).
Stock 4th gen Prelude VTEC rear mount on right (4th and 5th gen Accord LX/DX and 4th gen Prelude rear mounts are very similar).
Inserts for Prelude mount.
Prelude mount with inserts.
The EX rear mount is horrible. Replacing with a DX/LX/Prelude mount is so much better, but you need a DX/LX/Prelude rear engine mount bracket as well.
Edit: PS yes the EX rear crossmember already has the proper bolt holes for the 3-bolt-pattern of the other mount.
[Modified by 4doorH22, 2:20 PM 12/28/2002]
Old Dec 28, 2002 | 01:31 PM
niedejb's Avatar
Looks like the mount heights are different too?
No fitment problems? Ones a three bolt and the others a 4. The cross member has 5 holes in it then?
TypeRod
Dec 7, 2011 02:45 PM
boneRSXtypeStock
Dec 4, 2003 07:37 PM
Thundersquid
Oct 23, 2003 10:43 PM
