2 Q's no spark and what's the diff JDM type R and GSR
Old Aug 1, 2008 | 10:36 PM
racebum's Avatar
Default 2 Q's no spark and what's the diff JDM type R and GSR
first, here's a vid link to what i was doing with a bad GSR motor. this puppy only had 15psi in the cylinder i was messing with. when i pushed that plug back on the motor died and no spark ever since. what could get fried by doing this? the coil seems to be close to spec. can you take out an ecu or ignitor with spark wires grounding out on the block?
http://members.aol.com/c5in2004/teg.mpg
second, what are the differences between the JDM type r and GSR engines? both say b18c correct? is it similar to USDM differences? i'm very firmiliar with those.
Old Aug 1, 2008 | 11:15 PM
BlueIntegraBoy's Avatar
Default Re: 2 Q's no spark and what's the diff JDM type R and GSR (idrivesideways)
Yes, the differences between the SiR-G and ITR motors would be the differences between GSR and ITR motors.
eddie7978
Dec 21, 2017 03:08 AM
redDAinteg
Sep 30, 2009 06:28 PM
twentyhurtz
Feb 19, 2009 05:29 AM
oneprelude
Jul 3, 2008 03:33 PM
sicilian2k1
Jul 29, 2001 07:28 PM
