ls vtec into 91 crx si
Old Aug 1, 2008 | 09:27 PM
almostjdmeg's Avatar
Default ls vtec into 91 crx si
Hey guys, i am planning on putting my ls vtec into my 91 crx si. Right now it has an ls obo-O in it. I am putting a b18a1 block and a gsr head from a 96 integra. My question is what wiring will i have to do to make it run good and vtec to hit. And what ecu do you guys think i should run. Thanks
Old Aug 2, 2008 | 08:31 AM
black0hatch's Avatar
Default Re: ls vtec into 91 crx si (almostjdmeg)
you use your stock si harness. you might have to change the injector plugs if you have the obd1 injectors. your also gona have to wire in vtec. and if i was you i would convert it to obd1. ecu is up to you because your gona wana get it tuned. if you buy a obd0 to obd1 harness it will come with the instructions to do all this.
Old Aug 3, 2008 | 06:27 PM
vtecb18c's Avatar
Default Re: ls vtec into 91 crx si (black0hatch)
you also have to change to dizzy to obd1 if you go that route...02 sensors too i believe
Old Aug 3, 2008 | 08:20 PM
Were can i get an obd0 to obd1 harness?
Old Aug 4, 2008 | 08:53 AM
xalents23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almostjdmeg &raquo;</TD></TR><TR><TD CLASS="quote">Were can i get an obd0 to obd1 harness? </TD></TR></TABLE>
http://www.rywire.com
LakeSquad_ed3
Oct 17, 2014 10:40 AM
andysrex
Feb 26, 2006 06:44 PM
DA6righthand
Oct 4, 2005 10:25 PM
BoRiCuA
Aug 25, 2004 04:57 PM
usdm_ED7
11
Jun 20, 2003 08:01 AM
