Burning too Rich
Old Aug 1, 2008 | 08:59 PM
OVA's Avatar
OVA
Default Burning too Rich
I have 1995 del sol the motor DOHC B16A motor..
How do you adjusted or stop buring too rich...
All 4 plugs shown it is burning , too rich...what can i do to make it better?
Old Aug 1, 2008 | 11:24 PM
2wheelhunter's Avatar
Default Re: Burning too Rich (OVA)
need more info is it modded? what aftermarket parts does it have? what ecu? any CELs? (check engine lights)
Old Aug 2, 2008 | 10:59 AM
OVA's Avatar
OVA
Default Re: Burning too Rich (2wheelhunter)
It is stock the B16a from japan...No after market part....Stock ECU....P28
Last two year ago I did pass the EPA and didn't drive the car almost two years and I did changed the plugs...
There is no engine code ...
Is there any adjustment I can change the engine to burn leaner?
Modified by OVA at 3:33 PM 8/2/2008
Old Aug 2, 2008 | 05:53 PM
that would be a tune sir
honestly it sounds like an o2 sensor.. try checking or replacing them
Old Aug 2, 2008 | 08:10 PM
OVA's Avatar
OVA
You may be right....I didn'y get any bad sensor code..
but I'll check is out....it there any way to check the 02 sensor going bad?
Thanks
808cruise
Aug 31, 2014 07:06 AM
averyvm
Nov 9, 2009 11:48 AM
98IntegraLSNonVtec
Aug 4, 2006 12:49 PM
crxtreme27
Mar 26, 2003 07:04 AM
neumonik
Sep 3, 2002 06:42 AM
