covert hf to obd1
Old Aug 1, 2008 | 07:51 PM
adeline's Avatar
Default help covert hf to obd1
I thinking of rebuilding my hf motor and I was think would i get better mpg if, I convert to obd1 and what ecu would I be able to use to run my hf motor? Any help would be great just picking your brain
Modified by adeline at 2:31 AM 8/2/2008
Old Aug 2, 2008 | 11:14 AM
adeline's Avatar
Default Re: help covert hf to obd1 (adeline)
so nobody on this entire forum has any useful information about my possible project.
well thanks for nothing
Old Aug 2, 2008 | 01:48 PM
HonDelso's Avatar
wouldn't matter the cx gets the same gas mileage, and that's the closest obd1 motor to match the HF. just a well taken care of the motor, tire pressure and adjusting the nut between the gas pedal and driver seat dictates how much gas you are going to consume. I have a 2k camaro ss and get 27 mpg and my father gets 18 mpg. My crx i get around 34 (DX with Si motor/trans).
Old Aug 2, 2008 | 02:09 PM
slowassEF's Avatar
Just rebuild your D15B6 and stay OBD0!!!
Old Aug 2, 2008 | 08:34 PM
draperj09's Avatar
Default Re: help covert hf to obd1 (slowassEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassEF &raquo;</TD></TR><TR><TD CLASS="quote">Just rebuild your D15B6 and stay OBD0!!!</TD></TR></TABLE>
x2
Old Aug 3, 2008 | 09:45 AM
adeline's Avatar
Default Re: help covert hf to obd1 (draperj09)
I want to get close to 50 or more. I get 38 in my dx with dx tranny. and i want more
Old Aug 3, 2008 | 09:54 AM
IndySporty's Avatar
you should rebuild it, then stick a Air/Fuel gauge and SAFC on there and go to tuning that bad boy down. I know someone with a 2000 Prelude SH that's getting 40MPG when driving easy thanks to the VAFC.
Old Aug 4, 2008 | 09:59 PM
draperj09's Avatar
Default Re: help covert hf to obd1 (IndySporty)
50+ would probably require tuning, weight reduction and distribution, and trial and error. some things I would start with is relocating your battery and having plenty of tire pressure and a thorough tune-up. certain types of spark plugs/wires/oil/ etc may effect it a little also.
Old Aug 5, 2008 | 09:51 AM
wrecked95civic's Avatar
Do some research on HHO gas fueled cars. I have an friend in upstate NY getting 60 MPG average from a 92 Caravan. The HHO systems work better with the older efi systems anyways. I bought an 88 EF sedan and that is what I'm going to do with that car. My thoughts are: 92 Caravan average mileage 18-20; Caravan on HHO= ave. 60 MPG; 88 EF ave. 35 MPG; 88 EF on HHO gas=100 MPG. I don't know for sure that is purely speculation. I am going to be gathering the equipment to make the system and installing it when I figure out why the Civic is not getting spark.
89loudcrxsi
Mar 30, 2008 10:26 PM
SupraRXZ
Jun 27, 2006 04:28 PM
freakaccident
Sep 28, 2005 05:50 PM
freezerburnv2
Sep 4, 2005 04:16 AM
Attoir
Aug 27, 2003 10:13 AM
