D/B Series questions...
Alright...
I had to replace the clutch in my '91 CRX HF D15B6.
I am going to be mad at myself if that new clutch isn't going to be used if (when) I get a swap. Will it work with any D-series? What about B-series?
I wish I knew more about different trannies/what needs to be replaced, someone please help me. Thanks
You should be able to use it with any d-series. It will depend on which tranny you use. You will not be able to use it with any b-series tranny. Hope this helps.
If you use the Crappy HF flywheel you can keep your clutch, but it sucks.. If you use a Si flywheel, you can get a bigger clutch... The HF one is just small...
Thanks.
Yeah I thought '92 and newer had bigger flywheels/clutches and more teeth...
so if I'm getting a d16z6 from a 92-95 Si/EX I can still use it, it just won't be as good one from that year?
ParistsCP
Oct 7, 2008 06:59 AM
mario_pic
Dec 31, 2007 11:36 AM
JapJunkie
Dec 1, 2005 06:24 PM
