need help safc install ek civic
Im installing a safc into my 96 civic ex, so i can tune it for boost. does anyone know exactly which wires i need to splice into, so far i done map wire, tps wire, still looking for rpm signal, power, ground, wires. can i run the power and ground from a diff spot or it has to be from ecu? Thanks
http://www.apexi-usa.com/pdfInstallation/46.pdf
If you know the SAFC wire colors/function, you can use this diagram for splicing.
http://technet.ff-squad.com/wiring.obd2a.htm
yes i looked at those 2 already, so will this work
ecu pinout --------- safc
Power Ground - ground
igp power source - 12v constant
how about rpm signal? where too?
i tried it earlier but will try again tommorow
Just ground the SAFC to a dash bolt. I believe A20 (ICM signal) is your tach signal. 12v constant wire can be connected to the [+B] on your accessory slot (#1).
EG type GTR
Jul 20, 2006 11:38 AM
