Axel problem
Just swapped out a SOHC on a Civic Si but the driver side axle wouldn’t engage all the way in. Try pushing it, use a rubber mallet and hammer the tip of axle, slide it inside the hub and bang it but it has a 1/4 inch gap between the seal. I’m using the same axle, so the axle by itself shouldn’t be the problem. Is something inside the transmission blocking?
I swapped out axle several times but this is the 1st time I have problems with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aristotle »</TD></TR><TR><TD CLASS="quote">Yes. 95% sure.</TD></TR></TABLE>
I actually took off the circlip and try installing it but it still did the same thing.
Of course I'm not going install it without the circlip.
t3601
Transmission & Drivetrain
Dec 3, 2009 01:53 PM
