clutch and flywheel
Old Aug 1, 2008 | 02:21 PM
fullthrottleking's Avatar
Default clutch and flywheel
i am buying a stage 1 exedy clutch and 9lbs flywheel i was just wondering will the flywheel make my daily driving hard? i heard its easy to kill the car
Old Aug 1, 2008 | 02:27 PM
BetaPhoenix's Avatar
Default Re: clutch and flywheel (fullthrottleking)
Your revs will drop faster in between shifts. What do you use the car for mainly, any other engine mods?
Old Aug 1, 2008 | 02:31 PM
Emmanuel2112's Avatar
my friend has a 7lbs flywheel and stock clutch daily driver. i drove it an love it.
Old Aug 1, 2008 | 02:46 PM
Dark@Powers's Avatar
It will be ok for daily driving. There are various people who use the fidanza 7.5lb flywheel and have no complaints for daily driving with it.
Old Aug 1, 2008 | 03:26 PM
Ricextacy's Avatar
Default Re: clutch and flywheel (Dark@Powers)
i have a 7.5lbs Fidanza flywheel with an Exedy oem clutch. the car is daily driven and the flywheel is just a plus when im running late.
Old Aug 1, 2008 | 03:34 PM
Hanmin's Avatar
it takes a little to gett used to, once you get the hang of it its easy. but be warned, if you drive another stick and go back to your car you might die out if your not careful=]
Old Aug 1, 2008 | 03:50 PM
Jintegragsr97's Avatar
You should be fine, I used a 9lb flywheel with a stage3 clutch for like 3 months and it wasnt bad. Now I'm using a CC stage4 clutch with 12lb flywheel and its harder to DD now.
Old Aug 1, 2008 | 04:28 PM
Default Re: (Jintegragsr97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jintegragsr97 &raquo;</TD></TR><TR><TD CLASS="quote">You should be fine, I used a 9lb flywheel with a stage3 clutch for like 3 months and it wasnt bad. Now I'm using a CC stage4 clutch with 12lb flywheel and its harder to DD now.</TD></TR></TABLE>
You DD with Stage 3 and 4 clutches???
Old Aug 1, 2008 | 05:22 PM
Default Re: clutch and flywheel (BetaPhoenix)
i use it to drive to work an home and out on the weekends i have a test pipe 2.5 catback aem v2 intake, im putting on skunk2 throttle body and manifold in 2 weeks when they get here
Old Aug 1, 2008 | 08:47 PM
Default Re: (Dark@Powers)
Yeah, Theres no problem with that. I'm about to go boosted soon so i will be needing a strong clutch hopefully at least 350whp DD
732xghost
Transmission & Drivetrain
Dec 4, 2014 08:15 PM
djteggy99
Sep 23, 2008 06:56 PM
jdm ek9 101
Jun 28, 2006 03:59 PM
UNKNOWN_MEMBER
Jun 30, 2005 09:45 AM
lozersk8er
Nov 9, 2001 06:45 PM
