Integra door panel feel off, will not stick because of heat...help
The panel on the door panel fell off. The heat melted the original clue and it was slowly pealing off. I used 3M Super adhesive spray. It seems to hold it very nice but when the temperature gets hot it melts and falls off again. Does anyone know a high temperature adhesive spray I can use? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l »</TD></TR><TR><TD CLASS="quote">The panel on the door panel fell off. The heat melted the original clue and it was slowly pealing off. I used 3M Super adhesive spray. It seems to hold it very nice but when the temperature gets hot it melts and falls off again. Does anyone know a high temperature adhesive spray I can use? Thanks.</TD></TR></TABLE>
have you tried the Adhesive that is used for headliners? It seems to be some kind of contact cement, where you need to spray both surfaces and let them dry for a few minutes until they are tacky to the touch, then you just stick them together...but it's VERY important to let them dry before you stick them together.
No I have not probably. The only thing I have tried so far is the 3M Super Adhesive spray.
Where can I get the product you mention, do you know the name or brand of it also?
Thanks.
Thanks.
i have gotten contact cement from Lowes and Home Depot before. It worked pretty well when i was covering my kickpanels. Now after over 3 years, they do have a couple spots that do not like to stay stuck down all the way. It will hold waaay better than that spray crap though; we used that stuff for speaker box carpet and could still peel it off sometimes.
ekcivic9
Dec 15, 2005 09:45 PM
simplegreenmachine
Nov 27, 2005 04:55 AM
