Rear disc swap
Old Aug 1, 2008 | 01:33 PM
jpnolan's Avatar
Default Rear disc swap
Hey guys I just finished doing the rear disc brake swap on my 91 ef off of a 91 ls. After I was done I was reading around about a proportioning valve (sorry i cant spell to save my life), and I'm wondering do I need a different one now that i have 4 wheel disc brakes? thanks also where is the valve located?
Old Aug 1, 2008 | 01:42 PM
efsublime's Avatar
it wouldnt be a bad idea to switch your stock prop valve for the 4040 on integras. its located on the passenger side strut tower.
Old Aug 1, 2008 | 01:47 PM
jpnolan's Avatar
front or rear? strut tower? THANKS
Old Aug 1, 2008 | 01:55 PM
efjones9's Avatar
Default Re: (jpnolan)
front...its the round thing with the brake fluid in it lol
Old Aug 1, 2008 | 02:03 PM
johnnyonth3spot's Avatar
Default Re: Rear disc swap (jpnolan)
No that would be a brake booster , check out this link it a prop valve and yes you will notice a difference. https://honda-tech.com/zerothread?id=1707477
jpnolan's Avatar
thanks a ton. except its not round at all.
Old Aug 1, 2008 | 07:05 PM
pxsx's Avatar
yeah just did the disc swap too on my crx. I was running the stock prop valve and I wasnt having any problems. but i decided to get the right one. No noticable differnce.
All the proportioning valve does is regulate pressure to the rear brakes during heavy braking to stop rear wheel lock up. so its safe to say that for regular street driving, you probably dont really need it. But if you plan on doing track then yes. Either way I would put it on just to be safe. you never know when some idiot will pull out in front of you and you need to slam on the brakes
Old Aug 1, 2008 | 07:33 PM
Aristotle's Avatar
Default Re: (pxsx)
90HFCrX
13
Apr 8, 2012 10:57 AM
kyle2436
Feb 22, 2009 05:32 PM
musasabi
Oct 31, 2008 04:54 PM
90dxhatch
Jul 14, 2004 04:44 AM
Blitzed
Feb 8, 2004 12:07 PM
