clutch not engaging
Old Aug 1, 2008 | 12:43 PM
thedudefromjerz's Avatar
Default clutch not engaging
I have a dohc integra with a cable trans. the clutch pulls up very lightly and doesnt feel like its engaging. I pulled the tranny and nticed the fins n the pressure plate were flat and not angled at all. could the pressure plate be bad? Ive been told the fins flatten when you bolt the pressure plate down?
Old Aug 1, 2008 | 01:07 PM
hatchling37's Avatar
Default Re: clutch not engaging (thedudefromjerz)
Yes, they do. Pull off the pressure plate and disc, make sure the flywheel's bolted down properly. How is your throw out?
Old Aug 1, 2008 | 09:54 PM
Default Re: clutch not engaging (hatchling37)
I installed a new throwout bearing so that should be good. how should i make sure the flywheel is bolted on right.? I put the flywheel on with an impact wrench
AWD: Jeff
Transmission & Drivetrain
Jun 2, 2010 08:04 AM
5thGenCivicKid
Dec 13, 2004 03:39 AM
boosted350z
Nov 27, 2004 06:49 AM
Just Checking In
Mar 27, 2003 09:41 PM
John
Nov 29, 2001 07:29 PM
