b18 swap, clutch not engaging
Old Aug 1, 2008 | 12:40 PM
thedudefromjerz's Avatar
Default b18 swap, clutch not engaging
Im swapping a b18c1 into my ef. It has a b16 cable tranny on it. I just put the motor in the car, and was going to set timing until i realized the crank would not turn. I tried lifting the clutch arm and turning but still wouldnt. I also tried putting the trans in nuetral with the shifter on the tranny but couldnt find nuetral.
also the clutch lever pulls up very easily like the clutch is not engaging.
so i pulled the tranny and the bearing moves fine but i noticed the fins on the pressure plate are flat.
what do you guys think the problem is
Old Aug 2, 2008 | 07:41 AM
Default Re: b18 swap, clutch not engaging (thedudefromjerz)
some1 gtta have some input
91crx-jace
Jan 11, 2009 06:41 PM
PINKS
12
Jan 13, 2006 11:09 PM
spaceman
Sep 24, 2003 08:47 AM
blackfrohatch
21
Jan 15, 2003 11:37 AM
