p/s pump bracket
i have a question, I recentlly removed my p/s pump, lines etc. but i noticed that the bracket that holds the pump in place is bolted on to the engine on one end and the mount on the other. i wanted to remove it and since im not using it anymore but i dont know if i can and not efect the way the engine mounts, i know that the bottom mount witch is allso the a/c compressor bracket is there but is it enoughto hold the engine in place? its a d16z6 engine, and did the engines that came originally with no p/s have this bracket? thanks for all your help
thanks for the info ill be removing the bracket tomorrow. the support on the engine shouldnt be affected, right? i wouldnt be putting to much weight on the bottom bracket(a/c). thanks again
As long as you leave the driver side engine mount, nothing will be affected. Like I said, there are many D series cars that don't even come with that style mount or PS for the matter.
Boosted_JDM
Apr 9, 2007 03:45 PM
