Faile Emissions Test - 1991 CRX Si(D16a6)
Old Aug 1, 2008 | 11:39 AM
JesseCRX's Avatar
Default Failed Emissions Test - 1991 CRX Si(D16a6)
Well, I need help translating what this stuff means because the guy at the inspection shop was NO help whatsoever. He just threw me the report and said "take it to your mechanic."
High Speed Emissions Low Speed Emissions
HC(PPM) 160(Read 224) FAILED / 166 (Read 235) FAILED
CO(%) 0.90(Read 5.47)FAILED / 0.93 (Read 5.51) FAILED
CO2(%) (Read 11.2) / (Read 11.2)
NOx(PPM) 1179(Read 620)PASS / 1304 (Read 365) PASS
Dilution(%) >6 (Read 16.7) / >6 (Read 16.7)
Now here is what I have on the car...
New K&N Air Filter(Stock Air Box/Intake)
New Cat Converter
New DC Sports Cat Back Exhaust
DC Sports 4/2/1 Header
New O2 Sensor
New NGK Plugs/Wires
New Distributor
Fresh Oil Change
No CEL's
When I bought the car I noticed it came with an AEM Fuel Pressure Regulator but I'll be honest...I have NOT touched it nor do I even know how to adjust it. Maybe this has something to do with it.
Other than the car having a sticky throttle cable I dunno what else could be the problem. If anyone has any insight into my problem I would appreciate it.
Old Aug 1, 2008 | 03:36 PM
my91tealhb's Avatar
Default Re: Failed Emissions Test - 1991 CRX Si(D16a6) (JesseCRX)
JesseCRX,
It could be the header! Eventhough DC headers are supposed to be smog legal, I have never passed California smog check with it on. It would pass visual because it has a CARB # on it but once they hooked it up to the sniffer it always failed. Try taking it off and put the stock one on.
Old Aug 1, 2008 | 03:48 PM
JesseCRX's Avatar
Default Re: Failed Emissions Test - 1991 CRX Si(D16a6) (my91tealhb)
A header is going to effect the emissions? I thought it only effected the flow of the exhaust, not the actual contents of it.
Old Aug 1, 2008 | 03:56 PM
my91tealhb's Avatar
Thats what I thought~! Took it off and it passed no problem? Wierd huh?
Old Aug 1, 2008 | 05:00 PM
97grnrs's Avatar
press reg could be problem , use a stock one. its prob set rich or not even set at all. and the header too could worsen it.
Nooch
69
Apr 21, 2013 09:14 PM
rockcity
19
Mar 12, 2009 05:30 PM
Edulerp
Jul 15, 2006 02:48 PM
IshbOO
Oct 17, 2005 05:56 PM
IamVtec
12
Nov 2, 2002 01:05 AM
