I don't feel/hear VTEC
Old Aug 1, 2008 | 11:01 AM
beastman@'s Avatar
Default I don't feel/hear VTEC
When my car was stock, people told me that once I replaced my I/H/E I would notice VTEC engaging.
I got an AEM short ram, DC 4-2-1 header, Skunk2 test pipe, and APEXi WS2 exhaust. I still don't hear or feel VTEC kick in at 4400 or the secondary kick.
I did the Intake first and noticed a different sound/feel to my car, but not really any VTEC.
My WS2 definitely sounds different/better than stock, but haven't noticed anything performance-wise.
Old Aug 1, 2008 | 11:17 AM
devney's Avatar
Running the correct ECU? When VTEC engages on my gsr the exhaust tone definitely changes.
Old Aug 1, 2008 | 12:03 PM
GottaDC2's Avatar
Default Re: I don't feel/hear VTEC (beastman@)
do you have oil pressure? running temp can cause vtec not engage, the vtec solenoid has a screen in it that tends to get clogged, and dumb question but i have heard it before...is it vtec?
Old Aug 1, 2008 | 01:56 PM
Ricextacy's Avatar
Default Re: I don't feel/hear VTEC (GottaDC2)
try disconnecting the battery and itll reset ur ecu.
Old Aug 2, 2008 | 04:02 PM
beastman@'s Avatar
Default Re: I don't feel/hear VTEC (Ricextacy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devney &raquo;</TD></TR><TR><TD CLASS="quote">Running the correct ECU? When VTEC engages on my gsr the exhaust tone definitely changes. </TD></TR></TABLE>
Yeah it's the original ECU. No CEL or anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GottaDC2 &raquo;</TD></TR><TR><TD CLASS="quote">do you have oil pressure? running temp can cause vtec not engage, the vtec solenoid has a screen in it that tends to get clogged, and dumb question but i have heard it before...is it vtec?</TD></TR></TABLE>
My car is a GSR so yes B18C1 with VTEC, and I was up to running temp at the time. I believe I have oil pressure. If that screen is clogged will it cause VTEC not to engage? My car has 152,xxx so that could possibly be clogged to ****.
Old Aug 2, 2008 | 04:17 PM
Dogginator's Avatar
Daisy... Daisy...
You should not feel the VTEC "kick". If you do, it is not set correctly. The intake manifold on the B18C1 keeps the VTEC quiet.
Old Aug 2, 2008 | 06:40 PM
beastman@'s Avatar
Default Re: I don't feel/hear VTEC (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">You should not feel the VTEC "kick". If you do, it is not set correctly. The intake manifold on the B18C1 keeps the VTEC quiet.</TD></TR></TABLE>
Yeah, that's what I've been told in the past about the IM on the B18C1, but I was hoping after some mods I'd hear it rip. Can't really complain though, it still pulls as hard as I want it to.
Old Aug 2, 2008 | 07:03 PM
wegotmorrison's Avatar
Yeah dude, I have Intake+ Exhaust, everything else stock and you def. hear mine switch....
Old Aug 2, 2008 | 09:14 PM
JDM_CRX_PLEASE's Avatar
vtec cross over, i was told, is suppose to be smooth. shouldnt really feel/hear it but its there..
as long as your car pulls hard then its working.. you can tell when its not cracking, car feels like it has no power after the RPM crossover.
Old Aug 3, 2008 | 08:18 AM
sjbmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">as long as your car pulls hard then its working.. you can tell when its not cracking, car feels like it has no power after the RPM crossover. </TD></TR></TABLE>
well if he never had v-tec to begin with he would have nothing to compare it to now would he?
it really sounds like you should get this checked out, if you have no v-tec thats not really a problem its the the reason you have no v-tec that you should be worryed about
Old Aug 3, 2008 | 08:21 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: I don't feel/hear VTEC (sjbmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sjbmx &raquo;</TD></TR><TR><TD CLASS="quote">
well if he never had v-tec to begin with he would have nothing to compare it to now would he? </TD></TR></TABLE>
Good luck revving over 6000 RPM on the primary cam lobes.
Old Aug 3, 2008 | 09:33 AM
lsvtecboi'95's Avatar
who ever said you shouldnt hear/feel vtec is not a smart person... a major problem with vtec not kicking in is a little bit low oil.. you have to make sure it is correct.
Old Aug 3, 2008 | 09:53 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (lsvtecboi'95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecboi’95 &raquo;</TD></TR><TR><TD CLASS="quote">who ever said you shouldnt hear/feel vtec is not a smart person... </TD></TR></TABLE>
I said it and have owned a '97 GSR for 11 years.
Old Aug 3, 2008 | 06:22 PM
beastman@'s Avatar
Default Re: (Dogginator)
Good luck revving over 6000 RPM on the primary cam lobes.</TD></TR></TABLE>
I agree, because I have definitely gone over 7000 RPM.
Old Aug 3, 2008 | 06:30 PM
yc_dc4mar's Avatar
Default Re: (beastman@)
ummm it should cross over and you may fee a pull but not a kick...its not nitrous
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
I have had my GSR for 5 years, and it was definitely more pronounced audibly when I changed the intake. I still hear it change tones when I rev it up. I wouldn't say that I got mads vtack yoo in third or something, I feel pretty linear power all the way through, and I am untuned. I have done the basics plus cams and it pulls very nicely.
Old Aug 3, 2008 | 06:36 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (JDMThoughts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMThoughts &raquo;</TD></TR><TR><TD CLASS="quote">I have had my GSR for 5 years, and it was definitely more pronounced audibly when I changed the intake. I still hear it change tones when I rev it up. I wouldn't say that I got mads vtack yoo in third or something, I feel pretty linear power all the way through, and I am untuned. I have done the basics plus cams and it pulls very nicely.</TD></TR></TABLE>
Let me ask you this question: at what RPM does the VTEC engage? At what RPM does the intake sound become loud?
Old Aug 3, 2008 | 06:39 PM
beastman@'s Avatar
Default Re: (yc_dc4mar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yc_dc4mar &raquo;</TD></TR><TR><TD CLASS="quote">ummm it should cross over and you may fee a pull but not a kick...its not nitrous </TD></TR></TABLE>
kick, pull, whatever you want to call it. Splitting hairs...
Old Aug 3, 2008 | 07:02 PM
I notice at around 4400rpms it gets a little more audible, and at about 5900rpms I hear the second runners open. I am pretty familiar with my car.
Old Aug 3, 2008 | 07:03 PM
I am still running the stock intake manifold so there is there is what appears to be two different sounds of vtec being engaged, when in actuality it is just the secondary butterflies opening up.
Old Aug 3, 2008 | 10:54 PM
da_truth's Avatar
* B A N N E D *
Old Aug 4, 2008 | 12:17 AM
mfef4dr's Avatar
Default Re: (da_truth)
^ HAHAHA
Old Aug 4, 2008 | 12:53 AM
__oversea's Avatar
Default Re: (JDM_CRX_PLEASE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">vtec cross over, i was told, is suppose to be smooth. shouldnt really feel/hear it but its there..
you are right, but ones you put short ram intake, you can HEAR for sure.
Old Aug 4, 2008 | 01:44 AM
sjbmx's Avatar
potato, patato i love how he asked if vtec works and we all start aguing about when/how and what vtec taste like... lol at the vtec asian where did you get that?
Old Aug 4, 2008 | 03:28 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMThoughts &raquo;</TD></TR><TR><TD CLASS="quote">I notice at around 4400rpms it gets a little more audible, and at about 5900rpms I hear the second runners open. I am pretty familiar with my car.</TD></TR></TABLE>
You passed the test. I have J00 ITR cams in my '97 with a 4800 RPM crossover and no intake resonator. The sound is still subtle on that car due to the IAB. The transition is glass smooth.
