i need help with the cooling fan
Old Aug 1, 2008 | 10:38 AM
efjones9's Avatar
Default i need help with the cooling fan
i need the fan to run all the time how do i wire the fan so i can have it running continuously...help me out im new to the forum
Old Aug 1, 2008 | 10:46 AM
_Keith_'s Avatar
Default Re: i need help with the cooling fan (efjones9)
Hook it up to a swtich and a 12v power source
that way you control when its off and on
Old Aug 1, 2008 | 10:51 AM
efjones9's Avatar
Default Re: i need help with the cooling fan (_Keith_)
i have seen other cars without the switches tho?? i car do the switch bt id rather not use it..any other ideas??
Old Aug 1, 2008 | 12:16 PM
jlicrx's Avatar
unplug the connector from the cooling fan switch on the back of the block next to the oil filter and just connect the 2 wires together - the fan then should run anytime the ignition is on
Old Aug 1, 2008 | 12:29 PM
efjones9's Avatar
Default Re: i need help with the cooling fan (jlicrx)
is it the two wires wit a green and yellow stripe on it next to the oil pressure switch?
Old Aug 1, 2008 | 12:34 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efjones9 &raquo;</TD></TR><TR><TD CLASS="quote">is it the two wires wit a green and yellow stripe on it next to the oil pressure switch?</TD></TR></TABLE>next to the oil pressure sender - has 2-wires with a big round black rubber boot - wires are black and yellow/green
Old Aug 1, 2008 | 12:36 PM
efjones9's Avatar
aite thanx ims try it right now
crazyboy
23
Apr 27, 2011 03:02 AM
bignosewhipper
Jun 22, 2008 08:46 PM
97grnrs
Mar 17, 2006 01:54 PM
messeduprex
Nov 23, 2004 06:47 PM
