Heating problem?????
Old Aug 1, 2008 | 08:27 AM
mortificationrock's Avatar
Default Heating problem?????
Ok I have a 97 Ej8. Currently like all hondas I own the temp gauge never moves. But recently my temp goes up. I have some AC autotechnic gauges on my cluster so, usually its always between two dots. Now it reaches the next dot when im in a stop usually a drive thru. I mean what gives? Only does it at a stop and sometimes it doesn't do it. So its not all the time. Fan is kicking on cuz I can hear it. Could it be my thermostat? That's getting stuck just sometimes or what. Usually I've noticed that it would stay up until I accelerate. Not the water pump right?
Old Aug 1, 2008 | 08:40 AM
Syndacate's Avatar
Default Re: Heating problem????? (mortificationrock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock &raquo;</TD></TR><TR><TD CLASS="quote">Ok I have a 97 Ej8. Currently like all hondas I own the temp gauge never moves. But recently my temp goes up. I have some AC autotechnic gauges on my cluster so, usually its always between two dots. Now it reaches the next dot when im in a stop usually a drive thru. I mean what gives? Only does it at a stop and sometimes it doesn't do it. So its not all the time. Fan is kicking on cuz I can hear it. Could it be my thermostat? That's getting stuck just sometimes or what. Usually I've noticed that it would stay up until I accelerate. Not the water pump right?</TD></TR></TABLE>
It's not the thermostat, the thermostat only is closed when the engine is cold. After the engine is warmed up, it's open, and stays open. If it was stuck closed, your engine would overheat right away until you shut off the engine, or it ate itself. If it was stuck open, it would take a hell of a long time to open up. They don't "open and close" while you're driving and the like.
The evidence points to your fan not kicking on when it should, but you said the fan is kicking on fine because you can hear it, which means it's possible that your ECT (the electronic coolant temp sensor which controls when the fan kicks on) isn't operating 100%, leading to it not kicking on when it should.
Old Aug 1, 2008 | 09:15 AM
Default Re: Heating problem????? (Syndacate)
That's the switch that's in the thermostat housing right?
klinster
Jan 17, 2009 01:08 PM
integraslut78
Aug 13, 2008 10:35 AM
B6teen
10
Dec 23, 2006 05:55 PM
tuphatt
Jan 29, 2005 08:06 AM
Bulldogg83
Jul 15, 2004 05:44 PM
