Painting a valve cover on a integra and the side moldings????
Old Jul 21, 2002 | 11:25 PM
integraautox's Avatar
Default Painting a valve cover on a integra and the side moldings????
Hey does any one know where I could purchase a valve cover for a b18b engine in the color of red or how hard it would be to paint my self . Also if you take off the side moldings on the integra are there holes or no. If so should I take it off and cover up the holes or should I just paint the side molding. About how much would that cost also.
Old Jul 21, 2002 | 11:36 PM
o_Rage_o's Avatar
Default Re: Painting a valve cover on a integra and the side moldings???? (integraautox)
BSQ has great instructions somewhere on painting a valve cover red, he basically used a special textured spray paint, some alcohol, a razor and masking tape.
I remember seeing the pics and it did come out textured and looking clean.
Hey I found the pics! and instructions...congrats! <thank bsq for this!>
Instructions:
1.) Clean valve cover with soapy water to remove oil & grease and then rinsed with clean water.
2.) Drive car for a few minutes to dry the water from the valve cover.
3.) Remove valve cover from car.
4.) Wipe off inside of valve cover to remove all oil.
5.) Place valve cover on newspapers or other suitable material for painting.
6.) Tape off oil filler hole to prevent paint from entering valve cover. Also taped off valve cover stud holes for the same reason.
7.) Apply thin coat of Vasoline on all exposed letters that I did not want to paint.
8.) Apply several even coats of VHT Wrinkle Plus Red paint (SP-204) to valve cover.
9.) Let valve cover air dry for 45-60 minutes.
10.) Carefully removed any tape that has been applied to the valve cover.
11.) Place valve cover in oven for 30 minutes at 250 degrees, then 300 degrees for 15 minutes. (optional)
12.) Remove valve cover from over an let it cool. (optional)
13.) Take a razor blade and remove paint from letters. Using a little paint thinner on a Q-Tip clean letters to remove any paint which was not removed by the razor blade.
14.) Reinstall valve cover.
Edit: found proper instructions
-Rage
[Modified by o_Rage_o, 8:37 AM 7/22/2002]
Old Jul 22, 2002 | 01:51 AM
ragejed's Avatar
Default Re: Painting a valve cover on a integra and the side moldings???? (o_Rage_o)
How would I get the textured look but in blue? they only make red, grey and black.
Old Jul 22, 2002 | 04:55 AM
BSQ's Avatar
BSQ
Instructions:
-Rage
For future reference you can get these directions on my website at http://www.geocities.com/bretq/Valve...tructions.html
Old Jul 22, 2002 | 05:22 AM
Rory Breaker's Avatar
Default Re: Painting a valve cover on a integra and the side moldings???? (BSQ)
Thats very interesting...and it comes out "gritty" looking just like a stock valve cover, or does it look glossy/painted?
Old Jul 22, 2002 | 05:58 AM
BSQ's Avatar
BSQ
Default Re: Painting a valve cover on a integra and the side moldings???? (newgsrdriver)
The VHT wrinkle paint gives the same texture and color as the Type-R red valve cover. The picture above of my painted valve cover makes front edge appear somewhat glossy, but this was because I used the camera flash. The paint isn't glossy and it has the same matte/flat finish like the Type-R red valve cover.
Old Jul 22, 2002 | 08:12 AM
ragejed's Avatar
where can I get blue paint like that? or can I just use grey as a primer? and get a matt blue?
Old Jul 22, 2002 | 09:01 AM
mattL's Avatar
if you remove the molding it does leave holes which need to be filled and then most of the car if not all needs to be repainted, a body shop should paint them for approx $100
Old Jul 22, 2002 | 09:20 AM
BSQ's Avatar
BSQ
Default Re: Painting a valve cover on a integra and the side moldings???? (ragejed)
You might look into Dupli-Color™ High Heat Paint with Ceramic ( http://www.duplicolor.com/products/colors/highheat.html ). Dupli-Color offers a blue in the High Heat Paint.
igone916
Mar 28, 2009 07:54 PM
bigslimdog
84
Sep 3, 2007 05:52 AM
mantic6t9
Mar 27, 2004 01:19 PM
14eight
Sep 25, 2002 01:20 PM
vtec_powah
Sep 16, 2001 01:19 PM
